Results 1 to 10 of 14
Thread: diesel filter change time
    Nov 2009
    Warrington
    Default diesel filter change time
    hi all, its 4th service time, major service. im going to do it myself. planning on oil and oil filter air filter and fuel filter cant see what else needs doing, ive done all of the above work before on this car ( vec 1,9 cdti 150) other than the fuel filter, i know i need a filter removal tool but they all seem wayyyyy to expensive from what ive seen on line so going to have a look in machine mart at the weekend, has anyome bought such tools from machine mart or give me an idea of wheres best to get them, ill be doing the servicing myself from now on so id rather have the correct tools, as i dont want to brake anything in doing the job. thanks all. rob
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    I have a strap type filter spanner, Draper, £11.99. Does all I've ever needed!
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    All you need is an oil filter spider/ strap spanner/ larger grips to undo fuel filter.
    all we do in work is gently hold in a vice an use some big water pump pliers to undo then
    Nov 2009
    Warrington
    Cheers guys, hat about the fuel lines?? Ta
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    you can make a strap tool for little money.
    Sep 2012
    Vehicle : Insignia
    Trim : Sri Vx-line
    Year : 2011
    I used a small plain screwdriver to release the clips. Be careful tho!
    Sep 2012
    Vehicle : Insignia
    Trim : Sri Vx-line
    Year : 2011
    Quote Originally Posted by Al 22 dti View Post
    True! I used to have one made from an old timing belt!
    Nov 2009
    Warrington
    Also wanted to ask regarding doing the service myself. I've done regular oil and filter changes on this car many times but a mate told me he takes his to main dealer as they do updates etc on ecu ??? Is this true and am I best taking it to a dealer for the major service if that's the case ??
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Oil filter tool (belt or chain styles) from ebay 4 or 5 pounds good to use it on the diesel filter as well.
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    I work with 2 lads that came from Vauxhall dealership worked their for 5 years an they haven't done any ecu updates during servicing.
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. Diesel Filter - Help
    By houston in forum Engine & Drivetrain
    Last Post: 22nd August 2011, 15:11
  3. diesel filter
    By G4GAV in forum Diesel Engine related
    Last Post: 2nd October 2010, 15:04
  4. diesel filter change
    Last Post: 15th June 2010, 23:40
  5. where is the diesel filter???
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2009, 22:26
