Results 1 to 10 of 19
Thread: 3.2 v6 thermostat
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Default 3.2 v6 thermostat
    so next month should be fitting a thermostat to one of these.
    but whilst bored in work thought if look in auto data and it has a book time of 1.7 hours to fit.
    which tells me its gonna be a **** to get at lol
    anyone heat done one? Any tips on it.
    Or any pictures of its location?
    its an automatic incase that makes any difference
    cheer guys
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    Had it done myself at the stealers but saw the car stripped down. You need to take the plenum off to get down to it, look for the spark plug howto on here, it's not too hard, then you can see the housing at the driver's side of the engine. If you havent had your plugs changed recently it's worth doing while you have it stripped down. when down there though they found my coolant flange seal had perished so that's worth checking too.
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by Yugguy View Post
    I'm doing spark plugs for him on service.
    Will have a look cheers.
    how long did they have your car for?
    Sep 2012
    Engine : 3.2
    Just a morning to do the actual work - the job itself was quick but they had to order in the flange.
    Full Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    33 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    This flange seal, is that for the thermostat flange? I shall check mine to see whether or not it was included and, if not, then I'll get one. Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Do you have to ake a lot off the engine to do spark plugs?
    33 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    The top of the inlet plenum needs to come off. It's covered in the How To section, I believe. I've got plugs to do on mine too. Paul
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Thanks i will take a look going to give mine a full service.
    Sep 2012
    Engine : 3.2
    Quote Originally Posted by GSiFan View Post
    , No mate, this wasnt the thermostat at all, it is a large thick metal plate with six holes in it for coolant to go round the 6 cylinders, and instead of a seperate gasket it has one built into it, and part of this had perished so I had to have the whole thing replaced. He showed me the part to be fair so I knew he wasnt having me on. It was weeping a very small amount of coolant and I'd have never know if I hadnt been having the thermostat changed.
    33 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    Thanks, Yugguy. :-) Was this part inside the thermostat housing or nearby but elsewhere on the engine? Got any pictures? I need to know what to look for and which asket to order before I rip mine to bits because I don't have another running car at the moment. Paul
  1. thermostat
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2012, 18:08
  2. Can anyone tell me what a thermostat does?
    By twinxster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:03
  3. Thermostat?
    By killa_uk in forum Engine & Drivetrain
    Last Post: 31st January 2012, 18:35
  4. can it be anything other than the thermostat
    Last Post: 20th January 2011, 22:36
  5. thermostat or thermostat kit?
    By IA76 in forum Engine & Drivetrain
    Last Post: 24th September 2010, 11:33
Vectra c 3.2 v6 thermostat
signum 3.2 v6 thermostat location
