Thread: remap recommend in or near birmingham
    Regular Member mattican's Avatar
    Mar 2011
    birmingham
    Default remap recommend in or near birmingham
    So im back on the old commute to a permanent place of work after being self employed, signum 3.0 v6.............can anyone recommend a remapper in brum or near please?
    Is it possible to have it remapped so i get better fuel economy for run of the mill driving and then abit more for when some fun starts??
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    You can save money from a remap, it all depends on how you drive really, if you use the power all the time then no you won't save money, if you potter along at 70 then yes you will. I can do Chesterfield to Bracknell (340 odd miles - mainly all motorway M1, M42, M40, M4) in my 3.0 and get 53mpg showing on the fuel comp (I know it's not forced to be 100% accurate - but I can do that run TWICE on a full tank).
    If you drive the same after a map you may get 3-5% better ecenomy, doesn't sound alot but if it's a 100 mile round trip 5 times a week then you'll get 15 - 25 extra, over ten weeks thats an extra 150 - 250 miles, an so on. If you do more miles, you save more money.
    You have to be a little bullish about it, just get to speed and put the car on cruise, if you need to pass anything then use the speed up/down on the cruise, don't brake hard, use engine braking where-ever possible and don't excellerate hard.
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Quote Originally Posted by LeeU View Post
    use engine braking where-ever possible.
    What difference does it make how you slow down? Surely the trick is to try and be smooth and slow down as little as possible so you don't have to accelerate again.
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    My remapped Bora diesel gave better cruising mpg after the remap.
    Regular Member concretefingers's Avatar
    Jan 2013
    Sutton Coldfield
    Trim : Breeze
    Engine : CDTI 150
    Mileage : 137K
    So To get back on track, Who is the best remapper in Brum?
    Dec 2010
    London
    8 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    I'm sure i've read on here that it's not worth remapping the 3.0 as the gains are minimal
    Sep 2010
    6 Post(s)
    Trim : SRI
    You'll get around 215 - 230 bhp without changing anything else, there was an op on here that had his Y30DT mapped, made good figures too. The BHP may not be overly high but the torque is through the roof.
    Mar 2011
    birmingham
    Thanx leeU, good info........................so obviously still looking for a remapper, anyone had any dealings with DCP Tuning?? they're a mobile mapper, is it better to have it done on an RR??
    Feb 2013
    A Higher Level
    Vehicle : VECTRA C
    Trim : YES
    Engine : 1.9 CDTI
    no a rr is only good for measuring the increases. forget the image in your head of someone messing with a laptop tweaking figures on a laptop, while runnning up on a rr, its hollywood, its not possible to live map 95% of the ECU's out there and decreasing by the year as the microprocessors inside change in bit size meaning checksum RSA's get more complex. Only 8 bit EEPROM can be properly emulated on the RR. Most need a tweak and full flash between runs and thats ££££
    Plus a good tuner knows what to change and does not need a rr to prove the increases, I know from experience.These cars either need the Chip removing reading, mapping and soldering back or on later ones they can be done in boot mode via a special J-tag device on the Denso and its not as cheap as a OBD flash
    its unlikely a mobile remapper linked to a master dealer will have the skills to touch this system. Its old school and the realm of real tuners only.
  1. Recommend Remap?
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2011, 17:29
  2. CDTI remap in the birmingham area please!!
    By renton608 in forum Diesel Engine related
    Last Post: 17th February 2011, 22:15
  3. REMAP CDTI 150-Recommend me someone in BIRMINGHAM & Tell me more!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 19th May 2010, 14:01
  4. ECU Remap In bIrmingham
    By sri_power in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2009, 21:34
  5. Recommend a garage for service in Birmingham
    By petesaysblimey in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2009, 16:12
