Thread: Leaking diesel from under filter can
    Regular Member dbgb25's Avatar
    Aug 2009
    Margate kent
    Default Leaking diesel from under filter can
    just on the way home notice the smoke coming from engine bay pop the bonnet and found diesel leaking from under the fuel can is to dark no to have a look whats wrong but will have a look tomorrow
    Engine : 1.9 CDTi
    Normaly leaks/weeps from the seal and drips down.
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Have you replaced / did stg to fuel filter recently?
    Aug 2009
    Margate kent
    no just star leaking when I drive home . And can I replace that seal ?
    Dec 2010
    chesterfield
    Take the filter out, undo the top and you find the seal in a groove under the top. I think there's a how to for this.
    Dec 2010
    chesterfield
    Aug 2009
    Margate kent
    But it leaks from under the housing from water sensor or some wear
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Proper pita this.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Bleed screw loose?
    Aug 2009
    Margate kent
    Quote Originally Posted by mally View Post
    Bleed screw loose?
    Maybe will have a look but looks like leaks from sensor
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. 1.9 cdti vectra fuel filter leaking
    By felix_19 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2012, 16:47
  3. Leaking oil filter.
    By xoborp in forum Engine & Drivetrain
    Last Post: 25th September 2011, 17:45
  4. Leaking filter
    By anthonynoelg in forum Vectra C / Signum Troubleshooting
    Last Post: 4th May 2011, 08:33
  5. oil leaking from filter housing
    By dicky3706 in forum Engine & Drivetrain
    Last Post: 30th November 2010, 11:01
