Thread: Front offside parking light bulb.
    North Tyneside
    Default Front offside parking light bulb.
    Just had the info come up on the screen that the front offside parking light bulb has gone. Is this easy to replace? Any advice would be welcome. 1.8 Design spec 06 reg if that makes any difference. Thanks.
    Regular Member owen_999's Avatar
    Aug 2012
    Hartshorne
    Vehicle : Vectra SRI 150
    Trim : SRI
    Engine : 1.9cdti 150
    I've just done mine "again" its needs a little effort but it can be done. Is a little tight. Whereabouts are you based?
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Have a look and see if you can access the relevant cap behind the side light, undo it anticlockwise and the bulb is at the bottom, just pull it off then disconnect it. I have the cdti 150 and I easily changed both bulbs (i have slender hands though) and I think you have more room in the 1.8 engine bay, could be wrong. otherwise you might have to take airbox off.
    13 Post(s)
    Quote Originally Posted by pilgrim View Post
    Is this easy to replace?.
    Either airbox removed (as previously mentioned) or bumper partially off and headlight out.
    Both take approx the same time. Having previously used both methods, I prefer the bumper off way as I scratched the back of my hands to hell when I went via the airbox route as there are lots of brackets and the like waiting to cut you.
    North Tyneside
    Default Parking light bulb
    Quote Originally Posted by azacbr6 View Post
    Thanks for the advice, I'll give your method a try as it seems the easiest at this stage. I'm not good enough to try other methods such as removing air boxes or front bumpers. The irony from my point of view is that I never use the parking lights I just want the screen warnings to stop and the bulb warning showing on the dash to disappear. In reply to another post I'm based in North Tyneside. Would Halfords do this bulb change or would it take too much time for what they charge?
  1. Parking light bulb warning keeps coming on and off
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2012, 09:21
  2. Front light bulb change
    By Vectrarmand in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2011, 15:54
  3. Offside Headlamp bulb replacement : SRI bumper, 3.0 V6 CDTI, pre-facelift
    By m8internet in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2009, 11:27
  4. Parking light check bulb light on and wont go off
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2008, 12:03
  5. Front Fog Light Bulb
    By Perry in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2007, 02:11
https:www.vectra-c.comforumshowthread.php181971-Front-offside-parking-light-bulb
vectra-c
vauxhall vectra parking light bulb
change side light bulb 2006 veçtra
vectra c replacement front parking lightvectra c front parking bulbvectra zc headlight parking light bulbvectra parking light bulbVectra parking light bulb modelvectra c dash bulb changeopel vectra c parking light which bubl2007 vectra side lamp bulb replacingreplacing parking bulb 2002 vectrainsignia parking light removalhow o you change a parking light on a vauxhall vectravauxhall vectra sri parking light not workingvauxhall vectra front side light bulbwhat light for opel astra parking lightvectra c facelift park bulb changeparking light vectra cchanging parking bulb vectra csidelight bulb replacemtn vectra cvectra sri change parking light bulbhow to replace parking light bulb on vauxhall zafira 1.9vectra parking bulb
