Results 1 to 10 of 25
Thread: Gear cable help please.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    Default Gear cable help please.
    Car is 1.9cdti z19dt 120bhp.
    On the way from work, gear starts coming out of 2nd gear at times and after about 5miles, gear was no longer selecting. Got out to investigate and this was what I found. Gear cable has broken.
    Can someone explain whether it is just a case of buying new cable and fitting? Is there any how2 for this or does anyone know how to go about it please? Thanks.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    yep just a new on pal remove and refit inreverse there abit of a pita but it needs doin
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    Quote Originally Posted by paulvectrac View Post
    Do you know if it is the same as the one on the Z19DTH 150bhp engine?
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    dont think it is mate the 120 and 150 are diffrent gear boxes not sure n cable @Critch will no
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    the cables are the same as far as i know But not certain.
    just give reg in at factors because summet like that an the price it's just not worth fitting secondhand parts.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    Quote Originally Posted by Critch View Post
    Thanks. Will call factors tomorrow to find out. You got any tips or guide on fitting this? Cheers
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Patience and a lot of swearing.
    Take the old cables out and then try and get the threads on the new cables set roughly the same. Will save the amount of adjustment
    a second set of hands to pull the cables inside the car helps.
    if your doing it at home on axle stands you may find it a but awkward.
    But just get it up as high as you can give yaself best chance
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    Okay. Thanks
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    Motor factors do not sell and referred to dealer but dealer wants £111 for the gear selection cable. Anyone know if I can get it cheaper?
    Part number is 55355351 EQ 41R.
    Nov 2012
    Derby
    Vehicle : Vectra 1.9 CDTI 120
    Trim : Energy
    Engine : 1.9 8v 120 BHP
    Mileage : 170, 000
    Here's a link to a How 2 that I followed when connecting new cables up.
    http://www.fueltopia.co.uk/m/blogpos...gPost%3A182447
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Gear cable puzzle
    By SlowCoach in forum Vectra C / Signum Troubleshooting
    Last Post: 29th January 2012, 17:00
  3. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  4. XBox 360 VGA cable and Advanced SCART cable FS
    By RSV_Ecosse in forum General items for sale
    Last Post: 2nd February 2007, 00:01
disconnect gear cables vectra
