Results 1 to 10 of 17
Thread: Y30DT Cambelt / Water pump change
    Regular Member dshelton999's Avatar
    May 2011
    manchester
    Default Y30DT Cambelt / Water pump change
    Evening all,
    I will be doing my cambelt at the weekend and i need as much info as possible. e.g. pictures/guides etc.
    I have read through all the posts and not really had any that have given me the best confidence
    Is the water pump hard to do? Can it be done after the cambelt or will it have to be done whilst all that is off?
    I have 3.0 v6 cdti 04 sri 90,000 miles
    Many thanks
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    @Critch is your man on this one. He's been giving me some advice on my coolant leak. Think i'm just going to go for a water pump change and get the belt done at the same time.
    You don't need the waterpump doing - it's driven from the crankshaft through a set of gears and not a belt, so unless it's causing you a problem you don't need to go near it mate. You'd have to dismantle half the engine to get to it...
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    As above mate no need for water pump to be done unless your having problems?
    looking at about 5 hours to fit a water pump.
    Cambelt on these is really easy to do.
    only fuel pump to cams.
    pretty quick job aswel.
    theirs a few pics of my belt in the v6 info page.
    not the best photos but gives you an idea.
    May 2011
    manchester
    Thanks for your speedy replies,
    I was getting worried that the job was going to be more than I thought. I am actually looking forward to doing my timing belt lol, (sad!)
    The timing belt kit that I ordered is a genuine Vauxhall kit and it has come with the tensioner and one roller thing. Will I need another roller?
    Thanks!
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    I would change both idlers and tensioner personally.
    not worth the risk of not doing it.
    May 2011
    manchester
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by dshelton999 View Post
    Thanks!
    Where did you get it from and how much you pay.... if you dont mind me asking
    May 2011
    manchester
    No not at all mate
    eBay, £90
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Bargain mate.
    tensioner costs that on its own from vxl
    heres link to my photo of my belt mate.
    also on first page it's got aux belt layout.
    http://www.vectra-c.com/forum/showth...ght-help/page2
  1. Just had cambelt & water pump done
    By aps in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:46
  2. Cambelt and water pump change
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 1st August 2011, 14:39
  3. Cambelt kit & water pump change
    By Pete1nlancs in forum Engine & Drivetrain
    Last Post: 30th July 2010, 19:07
  4. Y30DT 3.0 V6 CDTI cambelt change
    By m8internet in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2010, 19:45
https:www.vectra-c.comforumshowthread.php181909-Y30DT-Cambelt-Water-pump-change
y30dt
vectra 3.0 v6 cdti timing belt fitting
y30dt timing
vectra y30dt timing belt change
z30dt water pump
vectra 3.0cdti water pump change
vectra 3.0 cdti water pump change
y30dt problems
Y30DT how to change timing belt
vectra v6 06 waterpump
Opel signum 3.0 135 water pump how often change
d308l p9x 70 6de1 y30dt timing
d308l p9x70 6de1 y30dt water pump
is water pump driven by cambelt on vectra c
v6 vauxhall do yoi have to change waterpump when fitying cam belt
timing belt and water pump for vauxhall signum 3.0 cdti
vectra c cam bekt pics
vauxhall vectra 3.0 v6 cdti cambelt
y30dt water pump
signum 3.0 cdti cambelt change
water pump an timing belt kit for v6 vectra c
y30dt timing marks
opel vectra y30dt
vectra 3.0 v6 cdti fuel pump
