hi all, does anyone know the proper name or number for the bit of cable that runs from the connector in the wheel arch to the abs sensor plug on the hub.
mines warn through and iv tried to repair it but it must be goosed.
al
al
On the front wheels, the cable that comes out of the wheel hub is part of the wheel hub assembly - it goes straight into the ABS sensor inside the hub rather than via a connector. Part number 1 on this diagram http://ecat24.com/opel/catalog/part/...9,41550,41546/ - you can see a bit of the cable and the connector in the picture. Click the '1' in the diagram for a larger picture.
It's different on the rear - one the picture of the hub at http://ecat24.com/opel/catalog/part/...3,41570,41572/ you can see the connector that the wiring plug connects to and here http://ecat24.com/opel/catalog/part/...65/4053/41687/ you can see the various ABS sensor wiring harnesses for the rear (varies my body and spec).
the cable that comes off the hub connects to another cable that runs on the inside of the arch..... its the arch cable i need as its in two pieces.
Just got to vx an explain what it is you want and they'll find it for you.
http://prntscr.com/tfzsu
right.... this hub has got a long cable attached to it with a round plug on the end.... its that cable that i need the part number for.
http://prntscr.com/tg1cf
right in the middle of that pic, there is a white plug and that has a cable that plugs into the abs cable...
its that cable with the white plug i need but i cant find it anywhere..
ps.. sorry for robbing the pic lol.
i assume its the extension harness your after from the body plug to the
abs sensor plug which both ends are a grey in colour.
just the plugs alone are not available,its a full harness
which side do you require
