Thread: Fault codes
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    Default Fault codes
    As some of you will know I have been having issues with the battery light since having 2 new alternators on last year, it stays on (even now after doing over 1000 miles with it on)I plugged it in before but no codes came up, Now I have the car & spanner light come on, so I decided to plug it in again to read cars computor and these are the codes that came up:
    P0621-01 Generator lamp "L" control circuit malfunction
    P0380-08 Glow device general error
    Regular Member any-mgzt's Avatar
    cheshire
    14 Post(s)
    Trim : basic
    Engine : Z19DT
    Do the codes show as Present or Not Present?
    The Glow Device general error is a common code my Vectra has it and so does my sons Astra H, both cars run fine.
    wirral
    60 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    P0621 will be be side it's non genuine alt fitted
    glow one will be a glow plug at fault
    Nov 2011
    Buckinghamshire
    Quote Originally Posted by any-mgzt View Post
    Yes its a new & present fault, has a little difficult in starting in morning , a little birdie told me its glow plugs
    Nov 2011
    Buckinghamshire
    Quote Originally Posted by Critch View Post
    Critch - what you mean by the P0621 one.. ??
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by SarahP View Post
    Who was the little birdie?
    Sometimes, an alternator that is not genuine (ie, not from Vauxhall), will throw the battery light on. Alternator is not faulty though
    Nov 2011
    Buckinghamshire
    Ahhhaaaa a little birdie from up north lol so basically , it will always be on until a genuine one get put on? is there a way that the glow plugs can be looked at/tested and replace the one not working or do you HAVE to replace them all?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Haha
    Post 5 here >> http://www.vectra-c.com/forum/showth...-starter-motor tells you how to test the glow plugs.
    If they are the originals, I'd bet they'll all be performing poorly though If you're tight like me, replace the poorest glow plug
    wirral
    60 Post(s)
    Trim : Basic
    Engine : 1.9
    Ohm meter from top of glow plug to engine block should under 1 ohm
    quickest way to test them
    Jan 2008
    ipswich
    my battery flick up when switch off the motor only a quick flash on odd times is that common then
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
