Thread: Splutter at partial throttle and low revs on cdti 120
    Regular Member Gee-dub-ya's Avatar
    Feb 2013
    swindon
    Trim : ls
    Engine : cdti 120
    Default Splutter at partial throttle and low revs on cdti 120
    Done a lot of looking around at this and it would seem to point at the injector wiring but what i can't find for definite is if it's definitely the wiring will i be getting and eml as well? as i haven't got an eml on yet?
    My egr is just over a week old if that help at all so don't think it that.
    is there anything else to look that wouldn't throw an eml before i start fitting new plugs on it?
    Feb 2013
    swindon
    Trim : ls
    Engine : cdti 120
    Can anyone tell me if the faulty injector wiring will throw an eml, or am i barking up the wrong tree ?
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Wasn't aware of any common issues with injector wiring on z19dt, only on dth. and on mine it was worst at full throttle.
    but my dth did used to judder/splutter at around 2000rpm even after new egr valve fitted. in the end I disabled egr and that cured it.
    Feb 2013
    swindon
    Trim : ls
    Engine : cdti 120
    Quote Originally Posted by littleteapot View Post
    Like i said i might be totally barking up the wrong tree,lol
    Does it not affect the 120's then? I've just been googling the symptoms and it kept leading to injector plugs or egr, but i've not had an eml
    and my egr is less than 2 weeks old. I'm going to strip and clean the boost control solenoid later as that seems to be the only other
    avenue. It's doing my head in now and i've only had it since sunday.
    Feb 2013
    swindon
    Trim : ls
    Engine : cdti 120
    Right i've stripped cleaned and lubed the boost control solenoid, removed and cleaned the boost sensor, i have a two week old EGR fitted, pinched
    the injector contacts up a bit, and it's still spluttering away if you drive it too gently but not showing an EML.
    Please can anyone shed any more light on this???????
  1. My CDTI 120 revs in to the red line???
    By Gibrunner in forum Engine & Drivetrain
    Last Post: 6th January 2013, 18:13
  2. throttle judder at low revs
    By Shutts in forum Engine & Drivetrain
    Last Post: 23rd September 2012, 23:24
  3. Replies: 43
    Last Post: 8th June 2011, 21:03
  4. no power at low revs cdti
    By brownlow39 in forum Engine & Drivetrain
    Last Post: 22nd May 2010, 19:39
  5. Partial clean of engine bay
    By Ollie in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2010, 11:45
vectra 1.9cdti splutters at 2000rpm
vauxhall zafira 1.9 cdti spluttering
jolty engine partial throttle z19dt
