Thread: oil change 2.2dti
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default oil change 2.2dti
    im wanting to do an oil change on my 04 2.2dti. found the oil filter location. under the car there is a tray, i know it has 2 flaps, for access to the fogs, is there one for the sump or do i have to take off the whole thing. im sure id read somewhere there is a service hatch
    Nottinghamshire
    Yes, there's a hatch secured by 5 bayonet-type screws. Undo them all and the tray drops down hinged at the front. Wiggle the hinge free to remove once the back end has dropped down far enough. Refitting is reverse of removal but make sure all 5 screws pop into place or they come undone.
    Regular Member Daywalker's Avatar
    Aug 2007
    Mitkunai k, Kaunas raj
    Vehicle : VW Jetta
    Trim : SE
    Engine : 1.4 TSii
    Year : 2017
    and its up to you but when i had mine i just left it off didnt make much difference and saves losing the screws
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Ok. Cheers. Il have a look
  1. 2003 2.2dti oil change help needed
    By Allenglish2003 in forum Engine & Drivetrain
    Last Post: 12th August 2012, 20:45
  2. 2.2DTi Radiator Change
    By si_hoss in forum Engine & Drivetrain
    Last Post: 11th August 2011, 20:08
  3. 2.2DTi Radiator Change
    Last Post: 6th April 2010, 09:17
  4. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
  5. how much is a cam belt change on a 2.2dti 02 please
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 07:32
