Likes Likes:  1
Results 1 to 10 of 23
Thread: Big 3 Upgrade
    Default Big 3 Upgrade
    Hi Guys,
    I am considering to do the "Big 3" upgrade. In other words, upgrading the following cables:
    1) alternator positive to battery positive
    2) battery negative to chassis
    3) engine ground to chassis
    There is plenty of stuff online about it but wondering if anyone has done this on a Vectra C? this may give me an idea of cable lengths and generally if its straightforward or not.
    I Hope to get some tips
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    I thought it was only older cars which befinited from this treatment?
    I added a ground wire from the alternator area to the O/S/F strut top - Didnt really make much difference.
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    It benefits any cars charging system, you can get up to 0.5v from doing the big three.
    Well I am considering the upgrade to improve my after market sound system, ive noticed the dash dimming slightly when i crank up the volume. It seems the factory cables are already 4 gauge, so could probably upgrage to 0 gauge
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Wouldn't it be better to upgrade the alternator?
    What Vectra do you have?
    I dont think Ill need a new alternator, im pretty sure Ill get away with the 120A stock alternator. I have a 2.0 DTI..
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Well the CDTi 1.9 one I think is 140A if you go that route
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    I've only ever bothered upgrading the battery earth and chassis earth on other cars as I always run a 2nd battery for my sound system, hopefully I can make a start on mine this weekend, I might upgrade the alt power cable when I do mine as I get slight light dimming issues as it is.
    If the current draw is too much for your standard battery then you may want to look at adding a 2nd one
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    How do you wire up a second battery? Series or parallel?
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    Parallel (+ to +, -to- ) think you just have to make sure its the same as the one in the front otherwise the smaller one will drag the bigger one down.
  1. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  2. gid upgrade
    By booker413 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2010, 16:48
  3. Looking to upgrade
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2010, 20:17
  4. upgrade on upgrade
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2009, 23:27
  5. upgrade done what next ?
    Last Post: 19th April 2009, 22:46
Vectra c big 3
the big 3 vectra c
corsa c big 3 upgrade
https:www.vectra-c.comforumshowthread.php181823-Big-3-Upgradepage2
