Results 1 to 10 of 19
Thread: vvt - remove airbox how to?
    May 2012
    UK
    Default vvt - remove airbox how to?
    Hi all
    Is there a 'how to' on taking the airbox out on the vvt? I can't seem to find one I need to remove it to replace my headlight bulb.
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Don't know about a How2, but it's very easy to do.
    All you need to disconnect is the electrical connector for the MAF, and also the pipe from the MAF to the engine (Big hose clip, 7mm socket I think). The clips holding the wiring loom to the side of the airbox should just pull upwards and slide out of their slots. No need to cut the tywraps. After that it's just a case of lifting the complete airbox/MAF assembly up and out of the car. If you start lifting at the rear of the airbox, it should disengage from it's rubber mounts no problem. Just need a wee shimmy to waggle it loose from the intake pipe at the front end after that. Refitting is just a reversal of instructions, making sure the airbox is correctly located into the air intake pipe and it's rubber mounts.
    13 Post(s)
    Quote Originally Posted by Chip View Post
    Just as quick and easy to partially remove the bumper.
    Regular Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    9 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    Move the airbox by what puppet says,i just done mine a few weeks ago-not too bad a job,and when you have the airbox off you can give it a good clean out.The changing of the headlight bulbs is then quite easy----Dave
    Barrow In Furness, Cumbria
    Takes 2 mins to take the airbox out. Look at my how to for the HID's to see the space you get with it removed and the pipes.
    May 2012
    UK
    Thanks guys, is it seriously easier to remove the bumper?! I assume this would be to fully remove the headlight... would they then need alignment?
    Nice design Vauxhall
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Just pop the airbox out, gives more than enough room to change the bulb. Had mine out at the weekend to change a sidelight bulb, takes 2 minutes to do.
    May 2012
    UK
    Quote Originally Posted by Chris SRi View Post
    At the risk of being a pain, do you have a link - can't find the exact article!
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Can't remember if regular members can view the How2 guides?
    http://www.vectra-c.com/forum/showth...tra&highlight=
    The last pic in the guide is basically showing the space on the drivers side where the airbox usually sits.
    Sorry, thought it looked better than that.
    The pipe at the bottom is the cold air feed that comes from the grill.
    Its a bit fiddly getting it off and back on but nothing a bit of patience can't sort.
    The only other pipe is at the top and a doddle to remove and refit.
  1. Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    By paul_sri150 in forum Diesel Engine related
    Last Post: 30th January 2012, 22:50
  2. How do I remove airbox to fit new bulbs
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2010, 10:45
  3. airbox mod
    By vectra_ in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2010, 21:35
  4. Airbox
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2008, 00:07
  5. Airbox Mod with K+N
    By nikroc in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2007, 21:11
how to remive airbox vectra c
vauxhall vectra air filter housing removal
vectra air box pipe removal
remove air box pipe vectra
vectra air box removal
how do I remove mass air intake pipe on vectra c 1.8 vvti
vectra c vvti 1.8 air box mod
vectra c air box removal
how to remove air box vectra c
vectra c air hose removal
