right I know there's no haynes manual for the signum, and it seems there's none for the vectra 2.0t either. is there a good general workshop manual covering this engine?
thanks in advance.
thanks in advance.
we need the saab 9-3 manual for our engines mate.. it is the saab turbo engine you have in there after all...
we call it the Z20NET, they call it the B207
thanks, good knowledge! I guess it should have been obvious from the jet fighter impression she does above 5000 RPM!
your welcome, loads of good info on this engine here on vec-c
true, I just want the manual for run of the mill stuff like servicing, is it the 9-3 02-07 manual which covers the correct engine? and is the engine bay layout pretty much the same?
yeah thats the manual.. the engine layout is the same, all parts on ours are stamped saab which you will notice once you get stuck into it.. The saab 9-3 however does have its power steering pump on NS side of the block though, on ours its under the OSF headlight behind the bumper. Apart from that is pretty much the same.
