Thread: Rad mounts
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    Default Rad mounts
    had car on four poster today to cure this annoying rattle at front which sounded like drop links, i checked prised barred swung on everything put rubber lube on all joints took car for a 6 mile drive still the kin same,so while under the bonnet i sprayed the mounts as some one suggested with lube back out for another drive only went about 100 yards and hey presto utter silence RESULT,so who every suggested it a big THANKYOU from me
    Regular Member Ozyboyross's Avatar
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Engine : 1.9 CDTi 150
    Mileage : 90k
    Got any photos of where to spray? I think that's What my noise is when I go over speed bumps as it gets a lot less when the engines warm? Makes no sense to me!!
    But I couldn't see the spring mounts anywhere on mine!
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    hi mate not sure how to up load photos,,but lift bonnet look under slam panel and u will see top of radiator follow along to edge of radiator and there some mounts they look simalar to the airbox housing mounts spray these with wd40 or sim i then rub some vaseline over top..if u still struggle pm ur number and i will talk u through it,,,HTH big tee
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Mileage : 90k
    Thanks mate ill have a good hunt tomorrow in daylight! Where's the best place to access them from? It's tight in that area on a 1.9 cdti lol
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Just literally look between the rad & slam panel, you won't miss them.
    or come to me & il do em for you lol. I was over the moon when I fixed mine!
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Mileage : 90k
    There easily spotted then? Mine does my head in coz it disappears once the engines warm
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    u need to be stood in front of car looking down under the s/panel as if your going to change a h/light bulb and they are there they arent a spring there more of a rubber mounting mines a 1.8 vvt so should be same
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    Quote Originally Posted by JJ0063 View Post
    and who told you about this lol ?
  1. rad mounts
    By chris1804 in forum Engine & Drivetrain
    Last Post: 30th January 2013, 16:31
  2. Top mounts
    By RBH in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2012, 07:49
  3. rad mounts help
    By n8sby in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2011, 10:21
  4. Top mounts??
    By LEW1S2006 in forum Suspension, Wheels & Brakes
    Last Post: 9th December 2009, 17:51
vauxhall vectra 1.8 vvt radiator www.vectra-c.com
