Thread: Non Vectra problem. Ford Ka
    Regular Member monkeybusiness's Avatar
    Wirral Merseyside
    Default Non Vectra problem. Ford Ka
    Dont really know where to post this thread, or if anyone on here can help. My daughter has a Ford Ka, and the heater doesn't work! All the radiator hoses are getting to the right temperature and the radiator, but it just blows cold air. I thought the controls may have stuck, but it seems to be operated electrically rather than by the old cable method. Poor girls freezing, can anybody help with any ideas?
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    It sounds as if the flaps that control the air flow have stuck (iirc its a common problem on F*rds of that era).
    From memory, if you drop the panel under the passenger side shelf you can get to the blower fan assembly - perhaps you may get a clue as to what is/is not happening?
    Wirral Merseyside
    No, the airflow is fine. The control for that still works, sending air up or down, but the temp always stays cold. The flow is mechanically controlled by cables and thats all ok, but looking under the dash, the temp seems to be controlled electronically. My other thought was a blocked heater matrix (I hope not, looks a pig to get at!)
    Thanks anyway
    Jun 2006
    Somewhere...
    Might be worth looking at a Haynes manual if you can.
    I wonder if you can bypass the electric valve to see if it does get warm? Or loosen the pipes each side of the matrix to see if water is flowing?
    Regular Member skippyroo's Avatar
    chasing the sheep
    i had that happen a beemer i had just bought , turned out it was the matrix, but got it changed under warranty, techie told me it was a b*tch of a job because of where the matrix was
    Feb 2006
    Dorset
    Its the electronic heater valve on the baulkhead , you need a new one .
    Wirral Merseyside
    Any ideas....Is that inside the car or under the bonnet? Is it accessable?
    Feb 2006
    Dorset
    should be under the bonnet on the scuttle panel , you will see the hoses going into it , you will need to remove the plastic grille brlow the screen to get access , and it will look like this
    http://cgi.ebay.co.uk/BRAND-NEW-HEAT...QQcmdZViewItem
    Wirral Merseyside
    Thanks Dennis, Im on the case. I'll get one tomorrow and try that.
    Cheers....MB
    Feb 2006
    Dorset
    no worries
  1. Ford Focus To VX Vectra
    By gavmckay in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2011, 23:07
  2. not a vectra but help would be appreciated (ford ka)
    By shb1988 in forum The 'Off Topic' room
    Last Post: 5th March 2011, 12:51
  3. ford Sony head unit into a vectra??
    By m111kan in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2010, 16:08
  4. Long Shot - Problem With Ford Puma
    By R13hard in forum The 'Off Topic' room
    Last Post: 17th August 2009, 19:11
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
