Thread: Fan not working - burning smell.
    Regular Member Paul Marsh's Avatar
    Dec 2012
    Cheshire
    Default Fan not working - burning smell.
    A few days ago, I noticed that when I turned the engine off, the fan was still going, albeit very slowly. I reckon it stayed on until I got back into the car, and was blowing a little stronger. I was worried, as this would be draining the battery. The car runs normally and luckily the battery seemed to be sufficiently charged to start the car.
    However, this morning, I got into the car and noticed a electrical component burning smell and now the fan control is totally dead. Don't think it's the fan, probably the control unit.
    Any suggestions? and anyone knows how/where to access the module? Going to take it to the garage, failing that, or at least make a couple of suggestions...
    p.s. all fuses are ok, and the dial was working on all settings the day before.
    Mileage : 000
    Sounds like the resistor pack had burn out. It is situated on the side of the fan motor. Is the scuttle panel blocked as water over flow will "short" out the resistor pack.
    There is plenty of info in the subject if you do a search.
    Dec 2012
    Cheshire
    Just took it out. The unit that attached to the motor comes out ok. Looks like it's melted and the plastic at the bottom. Also water came out, as it shorted out.
    I checked the motor and plugged a 12 v battery in. It works ok, but notice that little/no vented air is coming out.
    Just wondered what the two small wires are on the pack. I know the outer two are power, I reckon they must be a relay supply.
    Dec 2012
    Cheshire
    Update:
    Just been out now. The scuttle tray thing was clogged up, but the tray was empty. Took it out and a load of crud fell out/
    Hopefully, when I get the new unit, should be ok. Wonder if a service would've been part of the tasks? Should be...
    Thanks for all your contributions. Probably more useful knowledge here than the garage. They can be pretty useless at times
    Mileage : 000
    I recon there is far more knowlage on here than any VX dealer could impart.
    Best thing though. It is free.
    Dec 2012
    Cheshire
    I agree. Had a mis-firing on my other Vectra 1.8 petrol. They replaced the coil pack, but still mis-fired. I said it was misfiring on Cyl 3. Happens it was a faulty spark plug, not the coil pack.They plugged their computer in and guess: it was mis-firing on Cyl 3. I know, because I heard it!
    Waste of £200... Didn't go back there again!
    Dec 2010
    London
    8 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Make sure pollen filter is dry
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    you might hear a squeak every time you put the heater on now
    just keep an eye on it
    the water tends to rust the inside of the blower motor
    as above the pollen filter will be soaked so a new one at the dealers is about 11 pounds inc vat
    Dec 2012
    Cheshire
    The car's going in for service next week, so will be replaced then. Seems dry, probably accumilated water, due to the recent very wet days and not been using the car much, due to using work's vehicles instead.
    Hopefully it should arrive tomorrow and be back in business. Having to run the fan off a 12v battery next to me is annoying, if the window mists up, but at least it works...
  1. Burning Smell
    By Tam80 in forum Engine & Drivetrain
    Last Post: 13th April 2011, 11:36
  2. burning smell
    By mace in forum Engine & Drivetrain
    Last Post: 7th December 2010, 21:47
  3. burning smell!
    By MARK RC in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2010, 19:13
  4. Hmm What's that burning smell?
    By Stevel in forum The 'Off Topic' room
    Last Post: 9th March 2009, 21:22
  5. got my sri!!! burning smell!!
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 21:54
vectra burning smell and then battery flat next day
vectra c vvt engine smells hot
i was reversing my vectra an you can smell burning from front end when on heater
burnt plastic smell vectra
corsa c heater blower stopped working smell.of burning
fan motor burning smell not working
corsa c heater starting to smell
vauxhall astra burning smell when heating on
fan stopped burning smell
fan not starting burning smell
corsa c heater control dial burnt out
corsa c electrical burning from vents
corsa c heater motor burnt out
Insignia burning smell when fan heater is on
vectra 1.8 fan control
vectra burning smell and then battery flat next day site:www.vectra-c.com
fan heater burnt out in car
