Thread: Water leak!
    Jan 2013
    yorkshire
    Default Water leak!
    Hi all I've just found that where my flexy part of exhaust meets the next piece there's a bit of water coming out now I know this needs tightening up and I'll get round to it but should water be coming out? Also a slight leak from bottom of radiator. Would radweld cure this. Cheers
    Jan 2013
    aberdeenshire
    Vehicle : vectra life pre-face
    Trim : full canbus, pretty basic, :-)
    Engine : 1.8 petrol, 120hp
    Hi.
    Petrol cars do usually let a bit of water out of the exhaust, its a product of the catalytic converter doing its job. If its a heap of water itd be worth getting the car checked.
    As for radweld, ive never been a fan so ill let someone else chime in on that, although it probably would stop it.
    Jim
    Oct 2012
    Bedfordshire
    I wouldn't use the Radweld. Its the juice directly from the devil i used it on a previous car, then it subsiquently blew the HG easier (and possibly cheaper) to get the rad replaced! or replace what is causing the issue could be a pipe.
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    As Jimt said, it's a byproduct of the Cat... In go nasty fumes, out comes water and kittens.
    It'll look like a lot since it's just after that cat, as it normally dissapates throughout the whole length of the exhaust normally before leaving the backbox.
    And as for radweld... I'd rather fill my rad with eggewhites than that cr...
    Jan 2008
    ipswich
    or kceil thats good if spelt right
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    Get it warmed up then give it a good thrashing, get the revs up and blow the water out.
  1. Water Leak
    By Chris SRi in forum Engine & Drivetrain
    Last Post: 23rd July 2012, 21:43
  2. Water leak?
    By rmasifrafique in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2012, 22:17
  3. Water leak
    By Mark2.2 in forum Bodywork & Interior
    Last Post: 4th July 2008, 19:45
  4. Water Leak
    By acame2000 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2008, 10:17
  5. water leak
    By zubs187 in forum Engine & Drivetrain
    Last Post: 22nd July 2007, 18:17
