Thread: HELP! whining from the front
    Regular Member Ann's Avatar
    Jul 2011
    Northamptonshire & Derbyshire
    Default HELP! whining from the front
    I'm getting a whining coming from the front of the car, sounds like it is on one side only.
    It gets louder the faster I go.
    I still does it if I put the clutch in and take the car out of gear.
    I think it could be the wheel bearing, is there anyway to check this? There doesn't seem to be any play in the wheel.
    What else could it be before I replace the wheel bearing?
    It kinda sounds like a helicopter propeller
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    Mine sound likes that. Been told its a dry bearing in the gearbox or on one of the wheels. Vauxhall told me its because i have cheap branded tyres on it (idiots)
    Jul 2011
    Mine really loud I'm going to put the spare on the front and see if there's a change in noise. It has only started after xmas and nothing has been changed, ie tyres, wheels, brakes, it just started doing it
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    could be a tyre or possibly a wheel bearing
    East Ayrshire
    Trim : SRI XP1
    as above Bearing, but may also be a CV Joint
    Jul 2011
    Cv boot is fine, no slits and def no signs of leaks, no leaks coming from anywhere,
    Shock is all tightened up, ARB not lose, no play in bearings,
    put the rear wheel on the front, and I think the sound has gone quite a bit.
    So I think it is just my tyres or a buckled wheel
    East Ayrshire
    Trim : SRI XP1
    Hopefully it is something simple. Just for future tho, The cv boot doesn't need to be knackered to have a worn cv joint. They parts can still wear esp if the grease inside degrades a little bit as it does over time
    Jul 2011
    Ah ok you have a point. the car has only done 48,000 miles though, shame it needs mechanical assistance at this stage
    I will find someone with a VX I can just swap the 4 wheels over and take for a test drive I think
  1. whining noise
    By Swedge in forum Engine & Drivetrain
    Last Post: 21st November 2012, 23:23
  2. whining egr
    By donut in forum Vectra C / Signum Troubleshooting
    Last Post: 14th January 2011, 11:56
  3. whining egr valve
    By donut in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 20:29
  4. Steering whining!
    By Merick in forum Handling & Braking
    Last Post: 27th August 2008, 18:40
  5. Whining Noise
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2008, 09:08
