Thread: High Pressure Water Warning..
    spoons
    Guest
    Default High Pressure Water Warning..
    Heavy duty pressure washers could wreck car tyres in only 5 seconds, drivers are being warned....
    DEKRA found that aiming the spray directly at the sidewall can cause tiny, barely detectable holes to appear on the rubber. This greatly increases the chance for a blow out.
    It was also recommended not to use strong detergents with high pressure water as it can remove important protective chemicals from the compound.
    Its suggested that you avoid pressures of more than 110 bar...
    Regular Member Harry's Avatar
    Uxbridge, London
    i read that article, and it says not to keep the water jet pointing at the same spot for more than 10 ten seconds or something.
    i think provided you use the pressure washer in the 'fan' position you will be fine
    don't know why people would use 'jet' position to clean their wheels anyway!?!?
    Melbourne, Australia
    The instructions for my Karcher washer specifically warn that it can damage tyres when used at close range..
    Regular Member blr123's Avatar
    Dundee, scotland
    I can't see any reason why anyone would point the lance at the tyre concetrating on one area..........I simply hose them down then spray on APC, a quick brush then rinse again and apply a dressing.............good point though
    Bryan
    Jul 2006
    Bryan, is there anything you don't clean with APC? Just seems to crop up on a regular basis!!
    Jul 2006
    sorry.....
    I thought Detailers tried to stay away from pressure washers anyway, opting for a foam gun and a decent foam
    Uxbridge, London
    Quote Originally Posted by AJA View Post
    not the case.....practically all of the guys who detail for a living over on DW use pressure washers. generally accepted as a safe method of removing dirt provided it's used sensibly.
    it's either use the pressure washer to remove most or all of the dirt or go at it with a mitt and shampoo, which may induce some marring in the form of swirls.
    there's a guy on DW who has mastered the technique of a contact-less car wash, he prewashes using a foam gun, then blasts with a pressure washer, and repeats. provided the car is no caked in grime he doesn't have to pull out a mitt and go over it.
  1. Help with High Pressure Pump Z19DTH
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th November 2011, 20:59
  2. High Pressure Fuel Pump
    By trevteah in forum Engine & Drivetrain
    Last Post: 9th October 2010, 19:09
  3. High pressure fuel pump
    By dougiemc in forum Engine & Drivetrain
    Last Post: 3rd May 2009, 21:32
  4. High Pressure Fuel Pump
    By nesbigr0 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2009, 17:08
  5. Turbo, low or high pressure
    By Big Davie in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2006, 20:54
