Results 1 to 10 of 13
Thread: glow plugs
    Regular Member coooky's Avatar
    May 2011
    washington
    Default glow plugs
    i went to start the car this morning and the glow light plus took a while to go out about 3 times longer than normal now the engine managment light at the bottom of the dash wont go out if my glow plugs need replacing would this light stay on
    thanks
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Does it go out once car is upto temp?
    May 2011
    washington
    the glow plugs do but not the engine management light just drove 50 mile and the car is running fine
    Moderator paulhb's Avatar
    Wondering lonely as a cloud
    27 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Could be the glow plug relay mate as soon as the cars warm the glow plug relay should de-erergise, do you have a multimeter? If so then measure the resistance of each glow plug to the engine block they should be approx 2-5 ohms if the are then they are ok.
    May 2011
    washington
    once the car is warmed up and the glowplug light isnt on the engine light isnt on it was only starting from cold this morning
    thanks for the replys i think i will change the plugs only cheap so not to bad compared to the money that has been spent lol
    27 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Be careful a few have snapped theirs and then it is probably a head off job plenty of wd and let it soak for a bit.
    May 2011
    washington
    i will get the local garage to do them its easier
    plus hes a mate so prices are not to bad
    27 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Good choice they get old and brittle
    May 2011
    washington
    thanks for the advice
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    Yes be careful with glow plugs, i snapped 2 of mine. Car still starts fine, i have the EML light on for about 5 mins (if that) on first cold start up and then goes out. As the car starts ok it's not an issue at the moment so will save money and see what a garage says, i'm expecting the worst that the head needs to come off so will save and deal with it at a later date.
  1. Glow plugs?
    By SEANYboi in forum Engine & Drivetrain
    Last Post: 11th February 2013, 10:00
  2. Which glow plugs for 1.9 150?
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2011, 12:01
  3. Glow Plugs
    By RobW in forum Engine & Drivetrain
    Last Post: 18th March 2011, 20:05
  4. Glow plugs
    By danny1992 in forum Engine & Drivetrain
    Last Post: 9th September 2010, 11:52
  5. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
