And tips for changing Jubblee clip on turbo pipe?
Its the plastic pipe that goes onto the side of the turbo.
I noticed today the clip is very loose and wont tighten up.
I just bought a v large jubilee clip and fitted that..bit of a faff but doable. Cost £1.00.
Recently found mine was loose too, the VX ones are rubbish, put a wider better quality one on, just removed the old and fitted the new. 7mm spanner or small socket is all thats needed.
Did you do it from under the car?
I need to change all my clips again, standard ones are pap once been off and on a couple of times![]()
