Thread: Parrot install
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Default Parrot install
    Just installed a Parrot handsfree 3200ls that i got given. It's all in and working but as i was doing it i had a problem/ queery.
    When i was puching the HU (CD70) back into place the display was changing to 'External In'. What is this mode? When i use the 'Aux in' it displays just that and i wasn't aware that the ls3200 had any sort of additional input. There was a pink wire with a spade on the end of it attached to the iso lead that i bought when i taped up the end of it so it didn't ground on the chassis the problem was solved. Any ideas?
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    dont no it was spot on in my car before i gave it ys lmao
    Sent from my galaxy s3 lte
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Nothing wrong with it. Just curious to know that the mode is and how to utilize it if it's useful.
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    "Extern In" means that you've somehow grounded the telemute wire on the back of the radio. This shuts it up, says "extern in" on the display and allows whatever is telling it to shut up, (in this case the Parrot kit) to play.
    It's useful for cars that have the centre speaker on the dash, as without hooking the telemute up, you'll still get audio through that speaker, despite the fact that the parrot kit has cut off the rest of them.
    When you hook it up, it essentially says "shush" to the radio.
    Last edited by ThatAudioBloke; 25th February 2013 at 20:21. Reason: Sticking more info in!
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    so, let's say that i had the 9 speaker stereo and when i did get a call, the centre speaker stayed on, where SHOULD i connect it to, to solve the issue?
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    There's a yellow cable hanging off your Parrot kit, or there should be (but some people think it's useless and rip it out of the block). Hook that wire up to the pink Telemute wire (on the SOT lead), then when the parrot receives a call (or you're using the music streaming functions on an MKi kit, or just twiddling the control knob of a CK kit), it'll cut the music out, give you "extern in" and speak, or play, or do whatever is needed through the main speakers, and the radio will shut the rest of them up for you.
  1. My Parrot mki9200 install
    By Niall83 in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2011, 19:11
  2. show me your Parrot install please
    By Big Knox in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2010, 10:49
  3. Help required after Parrot install.
    By afcajax73 in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2010, 08:45
  4. Parrot 9200 Install Help
    By mickyd98 in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2009, 09:22
  5. Radio problem after install of parrot kit.
    By kenp in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2009, 13:30
