Hi, replaced these recently with LED ones but now I've just noticed I have no number plate lights at all.
Tried going back to the standard 501's and still nothing. Is this a fuse? Cant see a fuse in the handbook.
Anyone?
Have you put them back in their correct respective sides? When i did mine also the pins that held the bulbs got slightly splayed causing them to not make a connection. Got to be worth a try?
You could try putting standard bulbs in to check there is power to the light itself, and if so, try turning LEDs round in case they are the wrong way round. But if no power at all, it could be a case of following the cable back till you do find power.
