Hi guys,
Need your help again! tried to do a simple thing I thought and made a mess of it :-(.
There was a slight rattle coming from the boot at low speed on rough roads. Read the forum and decided to adjust the boot catch to stop the rattle.
So took off the plastic cover, loosen the screws, pushed the catch down (only went a few mm) and tightened back up. Tried closing the boot, closed ok but could still feel little movement when i try to move it up and down in closed position.
Then tried adjusting the rubber stops which I could not move by hand at all. Took a rachet and tried unscrewed the bigger hex thing on one of them that holds the rubber. It came out eventually but it seems I broke some part of it and cannot understand how it gets adjusted. It doesn't go back in properly now but somehow I have got it stuck!
Sat back in the car later on for a ride and guess what, the boot door open light on dashboard stay on. Tried opening and closing the boot a few times but light still on. Drove a bit and the boot rattle is much worse than before!!!
So the question is:
1. Why does the boot light on dashboard stays on? What could have I screwed here?
2. How to actually adjust the rubber stoppers? I need a simple layman explanation how to adjust them without breaking them. Also as I seem to have broken a bit of one, are they easy/cheap to get and from where?
Thanks in advance guys. This little thing is driving me nuts now.
Boot lid adjustment
