Thread: Yahoo! Done It!!!
    Jan 2013
    Hartlepool
    Default Yahoo! Done It!!!
    So My poor performance, blown turbo and everything I could think of checked and changed.
    Yesterday I reported of a Loud Hissing noise. It was the DPF pressure sensor pipe. Blown to pieces as the DPF is blocked. An obvious problem as I ruled out DPF due to the car doing daily long journies to commute. I whipped the DPF off and took it for a spin round the block. Wow! I now remember how it used to feel.
    So options now and I need some good advice here.
    Do I:
    Clean DPF with presure hose and re-fit
    Drill out its guts and re-fit
    Get a new piece of straight pipe and replace it
    Will the last 2 require a remap? I am looking for the cheapest option at the moment as I have spent all my money on the new turbo.
    Can I bash the insides out and re-fit it without a remap?
    And a note to all, if you loose your performance and cant find the problem check the DPF before it blows your turbo!
    Jan 2012
    Gloucestershire
    I smashed out the insides on mine and re-fitted. It then looks from the exterior like it should - this may be important for the more recent MOT rules, not sure. BUT, you need to have a remap to remove the regen cycle. I paid £300ish for the remap on my Vectra, but that was including an EGR delete and a economy/power map too. Well worth it in the long run as I used to get 45mpg and now get 50+mpg! Have passed MOT since too, no trouble!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Bash the inside of it out, and get it mapped out.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by DieselWig View Post
    Quote Originally Posted by tony-1977 View Post
    Ahemm gentlemen...........
    Carefully remove the DPF core material making sure not to damage the outer casing.
    Wear a mask a proper filter one if possible and goggles.
    You can soak the DPF with water first to keep the dust down, but it can splash black/grey wet soot/ash all over you as you carefully bash it out.
    Then get it mapped off.
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    A lot of the guys on my pug forum throw a lot of petrol into the dpf and burn the hell out of it to clear it.
    Jan 2013
    Hartlepool
    Thanks folks. As I can't afford the remap yet, will it do any harm to CAREFULLY remove the guts and run it without remapping until it can be afforded?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Do not run the car without a remap as it will try and regen and cause all sorts of problems including piles of smoke.
    You should be able to get a map which will include DPF and EGR delete and performance increase for £220
    Aug 2011
    Dudley
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTI 150BHP
    Mileage : 141000
    Sure I read somewhere that if you clamp off the small pipe going to the pressure unit it lets the ecu think there is low pre pressure in the filter. That said the saturation level will still increase as the mileage goes up and a regen will still happen regardless of the sensor.
    Jan 2013
    Hartlepool
    Thanks merikiito, I have been quoted £295 at a local place.
    I might blast the DPF with a jet wash as a short term measure to run the car
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Just be careful with the pressure washer as when we took my mates DPF it had collasped in the middle. We only found out when we started to bash the inside out and it all just gave way
  1. Yahoo running slow again
    By bobssignum in forum General Chat
    Last Post: 29th August 2011, 15:17
  2. Black smoke from exhaust - YAHOO ANSWERS
    By 123ashleyp in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 11:16
  3. Google & yahoo spiders.
    By mitch1965 in forum The 'Off Topic' room
    Last Post: 19th January 2009, 20:45
  4. Yahoo/BT Internet
    By MLC in forum General Chat
    Last Post: 24th August 2008, 14:44
  5. Yahoo
    By R-man in forum General Chat
    Last Post: 21st January 2006, 10:45
