Results 1 to 3 of 3
Thread: metalic sound when turning
    Oct 2012
    essex
    Default metalic sound when turning
    it sounds like metal on metal while turning. either that or a mouse stuck in one of the wheels. its ****** annoying, sometime i get it other times i dont.
    it seems to happen more often when i turn left after about a quarter turn of the wheel. i had new pads and disks installed about 2 months ago so i doubt its that but im open to suggestions.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I had something similar on the GSi a couple of years ago ... sounded like I had chains wrapped round the discs and was driving very slowly... but was far worse when turning/parking.
    After a few days hunting it down I eventually came to the small plate metal shields about 6 O'clock at the inner face of the front discs. It's below the lowest point of the hub and is a stone guard or something..... I got a big, flat blade screwdriver in the gap and levered it a way from the disc.... a handfull of stones and such fell out of either side ... and all was quiet once more.
    Regular Member Spelly's Avatar
    Derbyshire
    6 Post(s)
    As stated above. It sounds like your brake backplate is rubbing on the disc. A fairly common problem but really easy to fix
  1. Rough sound/feel when turning right
    By inovo in forum Suspension, Wheels & Brakes
    Last Post: 8th June 2012, 23:13
  2. Strange sound when turning wheel from centre??
    By Pacey in forum Suspension, Wheels & Brakes
    Last Post: 27th November 2011, 04:03
  3. Rubbing/vibrating sound when turning right.
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd July 2011, 10:22
  4. squeak sound when turning left and right
    By gibbon7000 in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2010, 22:17
