Results 1 to 5 of 5
Thread: squelching noise when braking
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Engine : 1.9 cdti 150
    Year : 2008
    Mileage : 119k
    Default squelching noise when braking
    Noticed a squelching noise coming from offside rear area when braking gently at slow speeds. Only noticed it when the weather is wet or damp. Braking efficiency seems ok.
    Anyone any ideas before I attempt to investigate the noise?
    Regular Member Desolation91's Avatar
    Jan 2013
    Chesterfield
    Trim : Elite, Tan leather
    Engine : 1.9 CDTI
    Mileage : 106000
    Is there plenty of pad left? Mine are making a horrible noise but that because they need new pads. Doing on sat!
    Glasgow
    A squelching sound is usually a seized caliper, after a drive you will probably notice more heat coming from the noisy one aswell.
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Year : 2008
    Mileage : 119k
    Will have a look at thr calipers and pads tomorow. Had the offside rear tyre burst this evening on a bit of road debris. Nice inch long gash in the inner side wall. So getting a new tyre fitted tomorrow too do seems a good time to check the brake noise.
    Seems odd that I only get the noise when the weather is wet or damp though.
    Jan 2011
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    check if they are aftermarket pads ?
  1. crunching noise under braking
    By drspamuk in forum Handling & Braking
    Last Post: 3rd October 2010, 16:50
  2. Noise when braking
    By richje100 in forum Suspension, Wheels & Brakes
    Last Post: 28th August 2010, 17:16
  3. squelching noise over speed bumps?
    By bigben in forum Suspension, Wheels & Brakes
    Last Post: 27th November 2009, 10:54
  4. Knocking noise when braking!!
    By dave collingwood in forum Vectra C / Signum Troubleshooting
    Last Post: 8th May 2008, 07:53
  5. Knocking noise when braking?
    By karlp606 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2007, 12:29
squelching from rear when braking
https:www.vectra-c.comforumshowthread.php181547-squelching-noise-when-braking
