29th November 2013, 15:16
#31
Originally Posted by
dougie89
mick 1986 there are slightly different outputs with different manufacturers but really you don't want them too super bright or you'll end up with too much glare on some of the buttons/dials, if you follow links to them that a lot of people have posted on here you won't go wrong, and in response to @
Sambecky1989 it's plug n play in so much as when you remove(de-solder) the old smd you replace it by soldering your chosen colour smd in it's place and you're good to go. so long as you've soldered it the right way round
Thanks for that mate. I just need to work out what colour I want to go for, then away I go with it, I'm leaning towards white, but not certain yet.
29th November 2013, 16:50
#32
ive got some white in mine and they look fantastic, and i've got blue and green and they both work too, everyones got their own tastes and as long as you like it thats all that counts i'm sure there's plenty of pictures on peoples garage pages and that to give you inspiration
28th March 2014, 10:20
#33
Anyone got a piccy of the facelift pcb for the Speedo cluster ?
30th September 2014, 10:49
#34
^^^ I'd like to see this also
7th November 2014, 21:08
#35
Has any one done automatic base plate LEDs what sort are they plcc2??
17th November 2014, 20:13
#36
leezsignum
I've just done my preface auto and they are plcc2's. I've found it easier to remove the board from inside the base plate and leave the ribbon cable connected down inside as I could'nt reach to unplug it.
17th November 2014, 20:36
#37
I'll be doing this some time in future so there are options to get them changed thanks JR521 for the info
23rd November 2015, 00:06
#38
Is it just me, or those PLCC-2 (3528) white ones are quite brighter then the original amber one, or at least the one I got .
According to theirs data sheet, white are 2000mcd, and the amber colored are about 1000-1300 mcd.
Can someone tell me where I can find lower mcd rated ones, please?
6th November 2017, 15:55
#39
Hello guys.
I want to do the LED conversion.
What's the type of the 14 side mounted LEDs?
What type are the yellow LEDs that light the icons? 3528?
Also I have 2 displays. The LEDs there have 4 mounting points. Are they bi colored? What types are they?
Thanks in advance.... Martin
6th November 2017, 18:58
#40
Nice thread revival........
Side ones - just use plcc2
Displays are plcc4 in sure, but u can use plcc2 as long as you use the top 2 pads.
Or you can use 0805's
