Results 1 to 10 of 16
Thread: Interior alarm started going off
    Aug 2011
    Dudley
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTI 150BHP
    Mileage : 170,000
    Default Interior alarm started going off
    Guys,
    My interior siren has just started going off for no reason. Went off twice so just reset it and the third time it went off I turned my headlight switch back to auto as thats all I did different on the way home and so far its not gone off. Seems very strange if that was the problem. The actual car horn does not sound(yes it does work) so the assumption is that its not been triggered, so could this be the resulting internally failing backup batteries?
    Regular Member Handyandy-UK's Avatar
    Mar 2009
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Used to get similar problems on Omega and Senator when the power sounder battery pack faulted or died, so you might well be spot on with your guess.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The horn will not sound unless the rear siren has been disconnected. The Siren is the only thing that is meant to sound when the alarm goes off. Built into the siren is a rechargeable battery which if failing can set the alarm off. If it persists then disconnect the siren and see if the alarm goes off then, if it does not go off then replace the siren and battery pack (all one item). If it continues to go off (will use car horn) then your issue is something else and you will need tech 2 to read the alarm codes to find out what is triggering it
    Aug 2011
    Dudley
    Mileage : 170,000
    If so can the batteries be changed?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The siren and batterys are a sealed unit
    Aug 2011
    Dudley
    Mileage : 170,000
    Nobody found a way to get them open? Is there any issue with just leaving it out the car as the main horn would still work I guess, is it monitored at all?
    If it is the batteries will it keep going off all the time or just three times like it just done.
    Mar 2009
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    There was a few who cut the casing open and replaced the pair of button cells... no idea how they got on long term though as not too long after I was 'overseas' for a while, but maybe you're in a prime position to see if such a refurb works on the Vectra system.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by wheelspin View Post
    If you leave it out the car (I have for the last 3 months) but it will show a fault up when you start the car on the GUID (center console screen) which once you press the main dial on the HU will clear it until you start the car again. not sure how much a new siren/battery is at the dealers but you can take a risk and get one off ebay
    Aug 2011
    Dudley
    Mileage : 170,000
    Forgot to mention in my first post, all the indicators were flashing when the siren was sounding. Is that normal with failing internal batteries? If it is an alarm issue can the alarm system be interigated with op-com to find out the problem.
    Mar 2009
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quite possible the ATWS is seeing the failing voltage from the powersounder as an 'attack' and thus triggering the warning... it may well be triggering the full system but if the powersounder has died you won't be hearing a lot.
    I would suggest the most a computer based application (CBA) could do would be detail any fault code generated.
    (Computer Based Application (CBA) - the polite way of saying anything such as Tech II, VauxCom, OpCom or any other application, without infringing the rules regarding naughty software)
  1. LED interior started
    By smartalec0310 in forum Styling
    Last Post: 3rd May 2012, 23:02
  2. For Sale: vectra interior roof light/alarm sensors
    By Caveman_nige in forum Parts for sale
    Last Post: 24th March 2012, 20:43
  3. my alarm sensor and interior light not working
    By nonpris in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2012, 22:57
  4. For Sale: Interior alarm sensor
    By lee gsi in forum Parts for sale
    Last Post: 8th August 2011, 20:06
  5. It's started already
    By neverlandandy in forum General Chat
    Last Post: 14th November 2010, 14:06
