I thought it would be handy stuff to have for finding boot leaks on the Vec
http://www.ebay.co.uk/itm/UV-Dye-UV-...888#vi-content
yes have it for when a block cracks and so on its spot on aswell
John you can just make your own, crack a green highlighter or two into a bowl with 400ml or so of water in and leave the sponge bit inside to soak for half an hour. Squeeze it out and you'll have some nice UV water. Dilute it then use it for whatever. Make a bit more and you can throw it in the cooling system. As long as the pen glows under UV, and UV source will show it up. I bought a black light bulb from the local art (couple of quid tops) shop and put it in one of the old style lamps for working on cars. Works great.
Seems useful
