I want to remove the front fog lights from the check control on my Vectra C 1.9 8v, reason being some one has rewired them and although they work fine the check control states bulb failure and warning light is on all the time. I have Tech2 available and want to know if they can be removed from the check control with Tech2.
Tech2 Reports that both Left and Right Fog lights are open circuit, at this time I do not want to have to mess around and rewire these correctly I have enough to do.
Do I need to change Variant coding to remove this?
