Thread: rear door driver side weathering seal issue??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default rear door driver side weathering seal issue??
    do not know what it is called but the rubber trims around the car that the door closes shut to. sort of weather seal if i am right???
    the top one of the rear door driver side. is always coming off the place it is supposed to be fitted to. causing wind noise and possibly water coming in.
    Anyone got a good method of securing it in place???
    What i have done so far is bang it back in place but when door opens and closes 2-4 times it pops back off. cant be helped cos my son uses that door to come in/out of the car.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is it in one of the corners?
    If so, I would guess that it needs stretching a little from all around, so that it isn't tight into the corner. Try pulling it off along the edges and pulling it tight into the corner before knocking onto the lip feature of the surround.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Top one, making the middle slack down. Did bang corners to stretch but keeps doing it.
    Should i take it down and sides and start top and stretch as i go to sides??
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    239 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Yes, just take it off completely, and refit it while gently stretching it as you do it, all the way around
  1. Rear Driver side door
    By dan21 in forum Bodywork & Interior
    Last Post: 15th January 2013, 14:50
  2. Remote/central locking issue with driver door
    By Archaon in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2010, 08:49
  3. Driver side door switch.
    By Quaternion in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2009, 16:49
  4. Driver side door / Clicking noise
    By bizerk in forum Bodywork & Interior
    Last Post: 22nd September 2008, 18:56
