Results 1 to 10 of 18
Thread: Ticking engine - injector deviations?
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Default Ticking engine - injector deviations?
    So I'm still trying to fix my ticking engine that started around 3000 miles ago now.
    Its a 2004 CDTI 150
    Brand new inlet
    EGR restrictor fitted
    82000 miles on the clock.
    I'm getting the oil changed this week to see if it helps.
    I plugged it into some diagnostics today & it shows oil pressure normal, I'm trying to locate someone with an analogue oil pressure gauge to rule out a knackered oil pump.
    Is there anything else it COULD be?
    Sticky tappet? If so how is this cured?
    My last idea is injectors? I got this result on an injector test at idle..
    I'm getting a fairly loud tapping noise from the engine, all temps & it doesn't go away. It's the typical ticking tapping noise.
    Heres a quick vid, il try and get a better one in daylight.
    http://i1279.photobucket.com/albums/...3F9EA89406.mp4
    Anyone able to help?
    Thanks, Jordan.
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Any ideas guys?
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    my 2.2 dti makes this noise on first start up until the engine is warm, but only on tickover, not when i use the throttle, so will be watching this
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    I just can't think what it could be I wonder if it is a tappet?
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    when was the oil last changed and what make/grade?
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Isn't there a thread where even if same grade the different type of oil or additives made a difference... Sure I read it on here?
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    It is due an oil change & on fact I've got the filter and oil in the boot. I've been to the garage twice now & they can't get the sump plug to budge! So I've got the parts myself & gonna get irwin bolt removers on it. Something is telling me its more than just the oil though.
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    the cdti 150 has hydraulic valve lifters poor oil will make them noisy/tick
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Sticky tappets maybe
    get a long screwdriver and press it against various parts of engine ie injectors whilst ear pressed against it. And get someone to rev and see where noise is
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    I see. Well I've ordered a set of irwin bolt removers so il get this ****** sump plug undone & rule the oil out.
  1. Cdti 150 ticking engine?
    By JJ0063 in forum Engine & Drivetrain
    Last Post: 10th February 2013, 23:31
  2. Ticking noise from engine??
    By Gracey in forum Engine & Drivetrain
    Last Post: 31st January 2012, 00:23
  3. ticking noise from engine
    By johnny ni in forum Engine & Drivetrain
    Last Post: 2nd December 2010, 23:16
  4. Engine Ticking (video included)
    By yoclick in forum Engine & Drivetrain
    Last Post: 12th August 2009, 20:39
  5. Engine ticking for 30 secs after start up
    By clive3373 in forum General Chat
    Last Post: 2nd May 2009, 22:24
cdti injector Deviation
