Results 1 to 2 of 2
Thread: Airbag Light On
    Jan 2010
    Nazareth, Israel
    Default Airbag Light On
    Hello,
    I have a 2003 Vectra C, 2.2l Petrol. Recently the air bag light indicator went on. I took the car for a check. Tech2 showed 2 issues. The first is related to loose connection at the driver side and the second is related to the "occupancy sensor" at the passenger seat.
    The dealer was able to clear the first issue however, is still troubleshooting the second issue... Note that the airbag light does not go on if the passenger seat is occupied.
    Any one is familiar with such a problem with the passenger seat (Code B0092)? Is it possible to replace this sensor?
    Thanks in Advance
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The problem with connectors under the seats coming lose is well known.... that's generally that cause of errors in that area.
    Always possible that the sensor is faulty ... appears to be item 10 here... and 'not cheap' :
    http://ecat24.com/opel/catalog/part/...5/40645,40649/
  1. Airbag light!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 01:52
  2. Airbag light
    By Sharpy28 in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 22:26
  3. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  4. Airbag Light
    By rocket999 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2011, 16:22
  5. Airbag Light
    By Hollingsworth87 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th April 2011, 16:29
