Thread: sticking throttle?
    Jan 2013
    aberdeenshire
    Vehicle : vectra life pre-face
    Trim : full canbus, pretty basic, :-)
    Engine : 1.8 petrol, 120hp
    Default sticking throttle?
    Well this was sooner than expected and not what i thought id be posting for :-(
    Got a phone call from wifey while i was at work and not a good one.
    She said she started the car, went to drive away and when she did the management light came on, the engine started to splutter, the revs fluctuated between idle and 1500 and there was no response from the throttle pedal.
    After a couple of attempts restarting the engine everything was fine.
    When i got home i did the pedal test and got the following codes in the following order:
    P0170 - Lean Exhaust
    P1525 Limp home position error
    P1550 Electronic throttle control
    P1526 Throttle position adaption error
    The last two codes have a choice of 4 from a list next to the code. Those are just ones i picked.
    Does this sound like the throttle body needs a clean?
    Im a bit lost and would like to get towards a solution before something happens
    Regards
    Jim
    Feb 2012
    sheffield
    Vehicle : SIGNUM 1.9 CDTI ELITE
    Trim : ALL OPTIONS ELITE
    Engine : 1.9 CDTI 150
    Mileage : 140,000
    What car do you have?
    If it is a cdti then I would guess a good place to start would be taking the throttle body off and checking the butterfly operation/clean it.
    Jan 2013
    aberdeenshire
    Sorry, its a 2005 1.8 preface petrol. I think its the 120Hp version but im not sure
    Dec 2010
    London
    8 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Yeh throttle body off and clean with carb cleaner not forgetting 1mm hole
    Jan 2013
    aberdeenshire
    Magic thanks, i thought it would be but needed to check.
    Regards
    Jim
  1. sticking caliper
    By skip85 in forum Suspension, Wheels & Brakes
    Last Post: 22nd June 2014, 12:49
  2. sticking callipers
    By gstore in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2013, 14:22
  3. sticking
    By HARRY SRI in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2012, 22:23
  4. sticking egr?
    Last Post: 11th July 2010, 20:01
  5. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
vectra c sticking throttle valve
vectra sticky throttle
vectra c sri 1.8 is stumbling under throttle
vectra 2005 throttle sticking
vectra 3.2 v6 sticky throttle
