Thread: Fuel leak cdti 150
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Default Fuel leak cdti 150
    Hi all, had a rant about this yesterday and thought it was sorted, but apparently not!
    Noticed a smell of diesel and some smoke coming from the back, turned out the fuel filter housing was leaking and the diesel was burning off the exhaust. Stripped it down, cleaned it up and it seemed ok, but it has started leaking again, albeit slower.
    I'm thinking replace the housing. Any other thoughts? Has anyone else had this? Completely random. I've not been near it!
    08 1.9 cdti 150
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    fuel filter is a pig to tighten mate, you need a vice and a tool like an oil filter removal tool in order to tighten it properly.
    Dec 2010
    chesterfield
    Take filter out and check the seal is OK.
    Sep 2012
    Vehicle : Insignia
    Trim : Sri Vx-line
    Year : 2011
    Seal is good. Checked it yesterday. Maybe I just need it horsed up some more! Due a filter change shortly so I'll maybe bring this forward before I get a housing, try a new seal. I only tightened on the car, so maybe I'll pull it out and stick it in the vice too. Cheers!
    Aug 2011
    Dudley
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTI 150BHP
    Mileage : 170,000
    Sure it's not leaking out of the drain tap on the bottom?
    Sep 2012
    Vehicle : Insignia
    Trim : Sri Vx-line
    Year : 2011
    Nah definitely round the threads. Why it started is beyond me.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    You must cover the new seal in diesel to form a seal. It needs to be torqued to 25 or 30nm... You will need to get that in a vice with the correct tool to do that.
    Sep 2012
    Vehicle : Insignia
    Trim : Sri Vx-line
    Year : 2011
    Cheers mate. Will get on it in the morning!
    Nov 2010
    Maidstone
    These filter housings are a git, you need to tighten them up so much it makes you feel a bit edgy. Has mine spew diesel out when ignition on before so i understand where your coming from.
    Sep 2012
    Vehicle : Insignia
    Trim : Sri Vx-line
    Year : 2011
    Ok, new filter and seal, all seems well, fingers crossed! Even bought a new filter wrench so I could torque it right! Cheers for the advice guys.
  1. 1.9 cdti fuel leak
    By gnomes in forum Engine & Drivetrain
    Last Post: 28th May 2012, 15:49
  2. Air/fuel leak
    By neill in forum Engine & Drivetrain
    Last Post: 24th December 2011, 17:07
  3. cdti fuel leak
    By duncmill in forum Engine & Drivetrain
    Last Post: 29th November 2011, 19:39
  4. 1.9 CDTI Fuel Leak Off Pipes.
    By felixx in forum Engine & Drivetrain
    Last Post: 6th February 2011, 18:28
  5. Fuel Leak V6 CDTI.
    By sb1uk in forum Engine & Drivetrain
    Last Post: 14th June 2010, 20:33
