Results 1 to 10 of 11
Thread: whats normal time for thermostat to warm up engine on 120 8v
    Nov 2011
    devon
    Vehicle : vectra 1.9 cdti
    Trim : sri
    Engine : 120 8v
    Mileage : 151k
    Default whats normal time for thermostat to warm up engine on 120 8v
    changed the thermostat the other week (right bar steward)
    but have been slightly surprised that it takes as long for the temperature needle to start moving as before.
    it does now however keep going through to 86* but i was expecting it to warm up quicker considering,plus maybe my old thermostat wasnt totally shagged,just didnt get the temp high enough.it has however definately improved the mpg which i am happy about.
    what are you guys doing mileage wise before it starts moving?
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    3 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Mine is generally after a few miles it starts moving up on the temp gauge and about 6-8 miles before its at correct running temperature
    Nov 2011
    devon
    Trim : sri
    Engine : 120 8v
    Mileage : 151k
    if thats the case,i will check my mileage and see what happens.its only now i have it worling that maybe compared with petrol,it must take longer i guess
    Aug 2010
    Leeds
    About 5-6 miles it starts moving my drive to work is all down hill so the car really is at 1400 rpm when i drive home up the hill it warms up much faster, plus it's parked outside all the time & the cars in a gargae may not get as cold as been outside.
    Dec 2012
    Devon
    I just had a new stat fitted on a cold morning say less than 4 degrees takes 20mins covering 6 miles or warmer mornings can be minutes!
    Oct 2009
    lincoln
    i can get all the way to work (26 miles) before it gets warm or anywhere near warm much below 80'c surely the stat cant be broken can it?? its never got warm since i have had it and ive owned it 4-5 years
    Oct 2010
    sittingbourne
    3 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Sounds like yours is shot, if it doesn't make it to 86 then needs replacing
    Nov 2011
    devon
    Trim : sri
    Engine : 120 8v
    Mileage : 151k
    Quote Originally Posted by bee View Post
    i changed mine for the same reason mate,didnt notice last winter when i bought it,as first deisel and knew no better tbh.if oyu got a 150 its an easy fit but the 120 is a right pain.make sure you get the uprated thermostat and watch your mpg go up as well as making it a tiny bit smoother on pcik up when warmed up properly.
    seems as though mine is the norm then,plus now using 2 stroke oil as well after clearing out the throttle body,so gotta be happy
    Nov 2013
    suffolk
    Vehicle : vectra 2007
    Trim : sri
    Engine : z18xer
    My heater starts to blow warm air on a cold morning after about 1/2 a mile, temp guage only gets up to 90deg after about 5 miles, outside temp 4deg - is this all about normal for a 2007 sri 1.8?
    Regular Member brimfull's Avatar
    Wrexham
    Trim : Vxr
    Engine : 2.8
    Diesels do take a longer to get up to temp compared to petrol engines
  1. Car takes ages to warm up....whats the issue??
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2013, 12:38
  2. Car takes a while to warm up, Thermostat? Vec C 1.8 Petrol
    By liam8282 in forum Engine & Drivetrain
    Last Post: 24th September 2011, 13:03
  3. Vectra C 3.0 V6 CDTi warm up time???
    By actionman in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 20:38
  4. thermostat..warm at last..
    By frasedeb in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 21:41
  5. 3.0ltr V6 Cdti Signum engine warm up time
    By kev666 in forum Engine & Drivetrain
    Last Post: 2nd April 2007, 20:57
vectra takes ages to warm up www.vectra-c.com
