What size socket is needed for the oil filter? Also what size for things like wheel hub as I'm buying a few larger sockets
32mm hub, 38mm oil housing or may be 36mm?
32mm shallow socket for oil filter it is do able with a standard socket just more awkward also recommend a long reach flexi ratchet.
i thought drive shaft bolts where 34 but could be 36 but to get actual hub off is 4 male torx bolts so you'll need e sockets think
32mm for the hub nut, 32mm for the filter housing and then a Female Torx socket of the 3 bearing bolts
Nice one I've just bought a 32mm shallow socket
