Thread: Vectra C 2.2 Misfire on Cylinder 3 + 4
    Jan 2012
    Telford
    Default Vectra C 2.2 Misfire on Cylinder 3 + 4
    Hiya guys, just wondering if anybody can shed any light, brought a Vectra 2.2 Direct last week its @ 110K, It went into limo mode earlier, after plugging into the diagnostic it said cylinder 3 + 4 Misfire. The car runs weird when cold, but 100% okay when its warmed up! Any Ideas guys?
    Sep 2011
    norwich,norfolk
    Compression test m8,sounds like head gasket,or ignition module.
    Jan 2012
    Telford
    Ahhh right, well im gonna eliminate the cheaper options first, im thinking spark plugs, coil pack maybe? am I on the right tracks?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    i was thinking try new plugs first followed by coilpack
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Does it go into limp when you get to about 3000 revs?
    Jan 2012
    Telford
    No, over the last few days i noticed the car and spanner come on in the odometer, when this comes on the car has been running a bit lumpy all of this only happens when cold, as soon as the engine has warmed up everything is 100% fine all day long.. its just that initial first drive in the morning.
    Cheers for your help so far guys
    Aug 2011
    Bristol
    Soo many of us with 2.2 suffering from misfire.
    A few of us have done various things.
    Start with plugs and coil and other possibilities are fuel pump and FPR (fuel pressure reg).
    So far I have changed plugs, coil and pump and no differance. FPR this weekend and checking throttle body for gaps and other areas.
    Compression test can give better indication. I was told cold is fuel pump but I just bought 1 for no reason
    Jan 2012
    Telford
    Yeah, cheers for that, car has been 100% this morning so im quite confused just gonna see how things pan out going forward, have ordered some plugs and filters cus its gotta be due a service anyhow.
    Thanks for your advice so far guys, had a few people mention head gasket failure but cant see how this would affect cold situations, temperature is all okay atm
  1. misfire on cylinder no 3
    By WRed in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2011, 00:50
  2. Misfire on Cylinder No 3
    By WRed in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2011, 13:58
  3. Misfire on Cylinder 4 - signum 2.2
    By H3MSY in forum Engine & Drivetrain
    Last Post: 18th January 2010, 13:53
  4. Misfire on cylinder 4
    By gavman in forum Engine & Drivetrain
    Last Post: 29th June 2009, 21:58
  5. misfire cylinder 4 vectra 1.8 club 52 plate
    By gavman in forum Vectra C / Signum Troubleshooting
    Last Post: 9th May 2009, 14:43
https:www.vectra-c.comforumshowthread.php181371-Vectra-C-2-2-Misfire-on-Cylinder-3-4
vectra 2.2 misfire
vectra c failure cylinder 4
vectra misfire
vectra c 2.2 petrol saying misfire on 1 and 4 injectors
vectra misfire cylinder 3
2.2 vauxhall vectra cylinder 3 misfire
vectra cylinder misfire
signum 2.2 cylinder 1 misfire
vauxhall 2.2 direct misfire cylinder 4
2.2 vectra 9 engine misfire
bobbin thread signum 2.2
vectra 2.2 mis fire cylinder 3 cold
vectra c misfire c2
