Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Can i cut my springs on my vectra ?? Please read
  1. #21
    Nov 2007
    Kent
    Assuming:
    your tyres are 225 40 18
    thus Diameter 638mm
    Circumference pi * 638 = 2004.336113 mm
    further assuming an approximate average fully stretched elastic band thickness of 0.5 mm
    You will need 2004.336113 / 0.5 = 4008.67226 elastic bands per layer of tyre coverage.
    To build up an a legal tread depth of 5 mm you'll need:
    4008.67226 * (5 / 0.5) = 40,086.7226 elastic bands to build up a 5mm depth over an 18inch tyre
    This takes no account of breakages.
    You already have 6 so only require a further 40,080.7226 elastic bands
    You will probably need a sturdy kitchen knife to temporarily split your tyre to allow you to split to allow you to slip the replacement rubber on and sufficient uhu or other such jointing compound to allow you to reseal your tyre. Hope that helps.
  2. #22
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    34 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    defintly DONT chop em mate, other people have pointed out crash risks etc but also itll eat tyres very very quickly
  3. #23
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by Dominic Brown View Post
    Assuming:
    thus Diameter 638mm
    But the legal minimum tread depth is only 1.6mm...
    ... think of the savings in rubber bands.
  4. #24
    Nov 2007
    Kent
    I stand corrected a revised figure to achieve required 2mm depth is in the region of 16,028.68890 (including allowance for 6 pre-existing bands in stock)
  5. #25
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    Quote Originally Posted by merikiito View Post
    Unbelievable that someone would even consider doing such a thing. All to save a few £'s
    Better off leaving well alone until you have the money to do the job correctly.
    PS: Does anyone know how many elastic bands I will need to replace a worn tyre. I cannot afford a new tyre so I'm collecting the elastic bands that the postman drops on his rounds. I have 6 so far.
    depending on the profile of the tyre will determin how many rubber bands you will need mine are 225/45/17 and i used 1,432 red rubber bands.need to start collecting again for the other 3 wheels. HTH GOOD LUCK
  6. #26
    Sep 2012
    dewsbury
    Vehicle : Vectra C Hatchback
    Trim : Sri
    Engine : 1.8 vvt
    Year : 06
    Quote Originally Posted by Ste View Post
    Progressive springs should not be cut, unless you want to reform the cut end. This needs specialist kit and heat treating properly.
    This would cost you FAR more than buying new lower (and stiffer springs). Also if you lower it significantly you will need to uprate your dampers. The originals will wear out much quicker otherwise.
    HOWEVER. You CAN cut the older parallel springs. I have done it before on my 1974 Triumph Stag. Needs must and all that. BUT these were much more simple to do, and the end could be 'flattened' to sit in the hanger fairly easily. I effectively lowered it on the front, when I fitted a much lighter engine, by about 55mm by cutting off 1.5 coils. The inherent increase in stiffness also helped to stop it feeling a little 'boaty'.
    Before anyone calls me insane. It was perfectly legit to do it, passed the MOT and was perfectly safe, as it was done properly and on suitable springs.
    Quite a few years ago ( 80's before anyone thinks I'm too old ) it was fairly normal to lower hot rods by cuttibg a coil off a spring, reheating it up and back into the correct shape and grinding a flat back on to let it sit properly. I spitted a post about the mot test elsewhere on here earlier today that said that a cut down spring was no longer an mot failure. I don't think the length of the spring affects its rate ( might be wrong on that one though ), I believe that thickness of metal, amount of coils has more of an effect so, why not?
  7. #27
    Sep 2012
    dewsbury
    Trim : Sri
    Engine : 1.8 vvt
    Year : 06
    Stupid small keys on phone
  8. #28
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    The main quality for lowering springs is their short travel. Cutting standard springs won't give you that at all : you'll just start too low, and since they'll still be soft, the car will litterally crash over the ground on bumps.
    I'm having factory lowered sports suspension and still find the springs too soft, and too low overall. If I'm going to change for "short" springs, it's only to get stiffer ones with a shorter travel, so the bumper and front spoiler will hopefully stop digging a trench into the ground each time going down a bump or ramp...
  9. #29
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    [QUOTE=Handyandy-UK;1986084]Be fair... yes, it's an utterly insane idea most likely to result in a crash and possibly death or injury.... but at least the OP had enough sense to ask first.QUOTE]
    It's worrying it was even thought of first. So no, I don't think some of the responses were unwarranted especially if there was no swearing involved.
  10. #30
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Ok, puzzling post.... I've re-read the thread again and I can't say anyone has claimed the responses weren't warranted - and that includes me.
  1. flashing leds on your vectra? read here plz
    By rozzer2006 in forum Electrical & ICE (including SatNav)
    Last Post: 4th August 2012, 00:56
  2. Replies: 5
    Last Post: 6th February 2012, 20:35
  3. SRI Vectra: Read and be warned!!!
    By Stringlabel in forum Vectra C / Signum Troubleshooting
    Last Post: 9th February 2009, 21:58
cutting front springs vectra c
vectra b cut springs
vectra c cut spring
cutting springs vs lowering springs vectra c
