Results 1 to 10 of 16
Thread: Thermostat on the way out?
    Regular Member John Bishop's Avatar
    Oct 2010
    Default Thermostat on the way out?
    Quick queery guys. Hearse runs fine with no error codes. MPG the same as it always has been. Heating works fine and temp guage on dash is fine when driving.
    However even when the engine is up to running temp and I am sitting for any length of time (10 mins) such as waiting to pick the kids up from school the guage drops to zero like when the engine is cold. Everything else is fine. Then when I drive away the guage goes back up to normal.
    I assume the guage is on it's way out, am I correct in thinking that?
    Oct 2010
    On thinking about it I dont think it will be the thermostat and must be something with the guage
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Sender fault perhaps ?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    What engine?
    Oct 2010
    Z30 Merikiito
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I would say thermostat. Its stuck open, I have found diesel engines cool down when idling unlike petrol which get hotter.
    Oct 2010
    It has only started doing it the last 3-4 weeks and the guage does the opposite to what you expect. Engine still stays hot and heaters blast out across the range from cold to hot on all speeds
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Most likely nothing is wrong. If I sit with the engine idling especially now that it's colder outside the guage will drop below 80 and even to "0".
    Regular Member Johnny-B's Avatar
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Hello!
    In which possition usualy is staying temperature gauge? Mine is between 85 and 90, but some time its moving between them! Of course if is doing REGENERATION its on 90!
    Regular Member sir pingu's Avatar
    Jan 2012
    Klarup DK 40 cm away from Keyboard
    Vehicle : Vectra Estate Irmscher 3.0 CDTI
    Engine : Z30DT
    Year : 11 06
    Mileage : 301000 KM
    Mine between 85 - 90 degrees.
  1. thermostat
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2012, 18:08
  2. Can anyone tell me what a thermostat does?
    By twinxster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:03
  3. Thermostat?
    By killa_uk in forum Engine & Drivetrain
    Last Post: 31st January 2012, 18:35
  4. can it be anything other than the thermostat
    Last Post: 20th January 2011, 22:36
  5. thermostat or thermostat kit?
    By IA76 in forum Engine & Drivetrain
    Last Post: 24th September 2010, 11:33
