Thread: DPF regen indication light?
    Jan 2013
    Finland
    Default DPF regen indication light?
    I`v read that Vaux (Opel here in Finland) removed this regen indication cause people thought there was something wrong with the car Well, there IS something with DPF. It`s the whole DPF concept that`s wrong
    Anyways, my question is can you somehow program this indication light to work? I`d like to see when my car is in regen. My BC is not enabled, so I can`t monitor mpg either. I can smell and hear (behind the car from exhaust) regen when stopped. But when on move I can`t tell when regen is in process.
    Well, I could get rid of DPF altogether, but here in Finland everything is so damn expensive, so I can`t afford it right now
    Oh, car is 3.0 cdti (z30dt).
    Thanks!
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    The problem with the Z30DT is that no-one knows the Denso management system enough to remove the DPF, you could bash out the insides and try various other methods but unless it was coded out you would hit issues.
    I know when my Z30DT is doing a regen then the MPG shows 1 g/hr opposed to the 0.1/0.2 g/hr when on idle and like you, when I'm moving I can't tell the car is doing a regen.
    One thing to keep in mind though, and I do this every so often, if you think you are due a regen, take the car for a spirited drive on the motorway, keep in 4th gear and try to keep the revs at 2500rpm+ and this should kick off the regen.
    Regular Member Dennisd's Avatar
    Oct 2010
    Netherlands
    Trim : Sport
    Engine : 1.9dth
    Mileage : 92000
    Well you can activate the DPF "active" light, but you have to purchase a happylightshow. This will allow you to activate that light + some other things.
    http://www.happylightshow.com/shop/o...-vectra-c.html for some more information.
    RO - Rocking all over the UK And Poland jaqubek's Avatar
    Sep 2011
    london
    36 Post(s)
    2 Thread(s)
    Vehicle : Vectra C Estate
    Engine : v6 3.0cdti
    thats what I got in my 3.0 cdti. Definitely worth it and you will get few options extra- follow me home lights, corner lights etc...
  1. DPF Regen
    By Andyc6845 in forum Engine & Drivetrain
    Last Post: 16th February 2011, 21:15
  2. what does Regen,,,
    By CLOMP in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 21:00
  3. service indication
    By KevinG in forum Detailing and Car Care Discussion
    Last Post: 20th April 2009, 17:04
  4. Spanner Indication on 04 SRI CDTI
    By Warrenmole in forum Vectra C / Signum Troubleshooting
    Last Post: 29th June 2008, 09:17
  5. Replies: 0
    Last Post: 25th June 2005, 16:27
how do i know when my 3.0 v6 signum is doing a regen
