Thread: Traction control on 1.8 SXI
    Jan 2013
    Huddersfield
    Default Traction control on 1.8 SXI
    Has my vec c 1.8 sxi got traction control and if so, how effective is it? Does it require any maintence? Only had the car since New Year's Day, car runs well but wants some tinkering ie. lambda sensors, cam belt change etc etc.
    Just not felt it kick in yet like it does on my discovery, obv two different cars completely.
    Thanks josh
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    don't think the 1.8 has it , easiest way is turn the ignition on , if you only have an ABS light & no light next to it then you have no TC .
    Jan 2013
    Huddersfield
    No, don't recall seeing one next to ABS when ignition is turned. Answers my question, new tyres may be on the card then as doing an awful lot of wheel spinning on uphill starts when not an abundance of acceleration. Many thanks for your quick response.
    May 2012
    county durham
    Mileage : 145k
    Quote Originally Posted by Joshuashaw View Post
    no worries
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    1.8 doesn't have it fitted mate.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    You need to upgrade you abs module to have tc. Don't pay any more than £40. And then you'll need tech2.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    [QUOTE=Joshuashaw;1985327]Has my vec c 1.8 sxi got traction control and if so, how effective is it? Does it require any maintence? Only had the car since New Year's Day, car runs well but wants some tinkering ie. lambda sensors, cam belt change etc etc.
    ive got the 1.8 there is no traction control on mine
    i had it before on my 2.0 vectra b and the traction control light kept on flashing on the dashboard when i did a wheel spin
    Feb 2011
    Selby
    Traction control wasn't fitted to any 1.8 litre Vectra as standard - however it was available as an optional extra on most pre-facelift models (apart from the LS). I don't have a post-facelift brochure to check whether it was on later models though.
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Bootful of revs and dump the clutch! If it spins it don't have it! Assuming a 1.8 can spin the wheels......
  1. my traction control how to
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2012, 20:01
  2. traction control
    By ggg1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 18:07
  3. 2.0T Traction Control
    By kryton01 in forum Engine & Drivetrain
    Last Post: 20th October 2009, 17:18
  4. traction control
    By jsnlvxr in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 21:56
  5. traction control
    By jamesv6 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 00:13
vectra 1.8 sxi traction control
