Results 1 to 10 of 13
Thread: cruise control fault, new stalk fix problem?
    newport
    Default cruise control fault, new stalk fix problem?
    i have a problem with the cruise control on our 2003 1.8 sri. its not something i use often, but would like it working properly.
    the fault seems to be with the top button on the stalk, it works intermitantly, ie i need to press it between 5-10 times before it works, the bottom button however works perfect, turn its on but obviously to the speed it was doing the last time, as soon as i touch the top button it cuts the cruise control off.
    so from what i can gather, the fault only lies with the top button, the bottom button and the rear long thin button work fine. i have read a few posts on here so tried the trick of putting my foot under the brake and clutch pedals to pull up to see if the switches are at fault but it makes no difference.
    is it just a simple case of getting a new (second hand) stalk and fitting it, will this sort out the problem, or does the problem lie elsewhere?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Remove the stalk, strip it and clean it. Worked a treat for me
    Took me about 15 minutes all in, following the How To on here
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 165000
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    BUT, remove the stalk the proper way with a paper clip, not by just yarking it out.....!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 165000
    correct
    newport
    yep, taken stalks out the proper way when breaking my last car, cheers, will have a go at that
    Regular Member mike.'s Avatar
    Oct 2012
    peterborough
    Trim : SRi NAV
    Engine : 1.9 CDTi 120
    i am gonna try this too.i have exactly the same fault.missed my cruise control last week on my way to manchester!lol
    Regular Member John Bishop's Avatar
    Oct 2010
    Rear long thin button?! I only have a top and bottom.
    Regular Member JM53 BEL's Avatar
    Oct 2012
    Clackmannan, Scotland
    Trim : Elgance
    Engine : 2.0 Turbo
    Mileage : 106000
    I have this exact same problem! I find if you pull stalk out then press top button it works, so think it just a dirty connection! I am going to take stalk out and clean it. See if that works, i use my cruise control all th time, i love it especially with the miles i drive to get to work.
    Jul 2011
    Leeds
    Vehicle : Insignia 160
    Trim : Elite Leather Light n Sight
    Engine : 2.0 16v
    Year : 2012
    Mileage : 50k
    Search for the Selotape fix or its all a waste of time.
    I bought a new stalk and it still didnt work.
    The cause is vibration,fixed with selotape !
  1. Cruise control stalk
    By chrisvectra in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2013, 01:15
  2. Cruise Control Stalk
    Last Post: 27th April 2011, 12:51
  3. cruise control stalk
    By n8sby in forum Parts for sale
    Last Post: 25th May 2010, 11:48
  4. Cruise Control problem fixed by lifting stalk
    By KevinG in forum Electrical & ICE (including SatNav)
    Last Post: 22nd May 2009, 23:26
  5. cruise control stalk
    By AL21784 in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2008, 16:14
opel vectra c stalk cruise
vectra c cruise control problem
https:www.vectra-c.comforumshowthread.php181287-cruise-control-fault-new-stalk-fix-problem
