Thread: Back end. Sway??u
    Jan 2013
    yorkshire
    Default Back end. Sway??u
    When I go over speed bumps the rear end seems to sway a bit. Does anyone know what this is likely. To be. Thanks
    Jan 2013
    yorkshire
    Forgot to say it's a vecci c. 2004
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    As in side to side or bounce up and down?
    East Kilbride
    Engine : 3.2 v6
    Mileage : 140,000
    Shockers
    3.2 v6 Signum and loving it 😁
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    upper control arms
    Jan 2013
    yorkshire
    Side to side mate
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Its going to be a failure on one side, but you should really replace in pairs. Go to both corners and in turn press down hard on that corner and let go, it should rise fall and settle. if one or more corners bounces more then its your shocks, there real easy to replace with only 2 bolts to remove. Next with the car on the ground, grab the top of the wheel and pull and push the top in and out, there should be no movement, if there is then your looking at the upper controle arms. These are harder to replace but still something you can do on the drive.
    Both things are common problems mate, but odds on it will be a sticking shock.
    HTH.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Banana arms and rear shockers
    Jan 2013
    yorkshire
    Thx everyone ill look in morning
    Jan 2013
    yorkshire
    Yes guys cheers 1 rear shocker bounced more than other so gonna replace. Both. Off side bounced like a ball. Near side seemed okthx
  1. VXR Sway bars
    By MBfromCTUSA in forum Handling & Braking
    Last Post: 13th August 2012, 16:07
  2. Rear anti sway bar?
    By bedo13 in forum Handling & Braking
    Last Post: 16th October 2010, 19:04
  3. Rear Sway Bars
    By Vectra_C_Chris in forum Handling & Braking
    Last Post: 9th June 2009, 15:39
  4. Help, the back ligth and back door not working after using hanger
    By joacom in forum Vectra C / Signum Troubleshooting
    Last Post: 19th April 2009, 15:24
  5. Milau Trip - back seat report...WE'RE BACK!!!!
    By Duncan in forum General Chat
    Last Post: 30th September 2007, 12:53
signum rear swaying
vectra-c
