Results 1 to 9 of 9
Thread: Why is nothing simple, feeling a bit deflated about the car now.
    Nov 2010
    Maidstone
    Default Why is nothing simple, feeling a bit deflated about the car now.
    After learning the exhaust flexi was broken i got the new part and set about fitting, up on the ramps, tray off, loosed front 3 bolts which were a breeze, then the 2 clamp bolts holding to gearbox, then attacked the 3 bolts on the dpf flanges. I knew these were going to be absolute and utter ball ache and nothing has been more true. I thought the top was going to be hardest down to access but that came out not too bad, but the lower 2 just rounded as i expected. Seeing as i dont have any turbo sockets i couldnt use them and these bolts have welded themselves in so tight i dont think they would budge without sheering. Im guessing these are in such bad condition due to having the most road salt/water abuse. So i thought the only action was to grind off the rounded nuts, drill out the studs and replace with new bolts/nuts with anti shatter washers. But this is where ive hit a massive wall, none of my drill bits will do the job. Ive managed to drill through the core of one with a 4mm drill bit and assumed the best action with steel is to open hole gradually but it seems not. Soon as i go to next step of a 6/7mm drill bit it just kills the bit, i can only assume i dont have the right bits but the ones im using are hs bits which i thought were for hard metal. I have reached that stage where im close to launching a hammer through the windscreen. Can someone offer some words of wisdom before i hang from the ceiling. Any input greatly welcome.
    Jul 2012
    Doncaster
    Well I know from experience there's drill bits and then there's drill bits, go and buy a good quality set.
    always gave things like that a long soak in penetrating oil then heated the bolts up with a blow torch and most come straight out, if they sheered then out came the drill/angle grinder, I don't have much patience so if the above failed it would be the sledge hammer and no I'm not joking : )
    Regular Member patch22's Avatar
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Earned my living in the engineering trade finished now pleased to say,came across similar situations on a regular basis,cobalt drill bits will do the job,but the key word is patience,these bits are very hard but very brittle have broke a few by rushing,don't know how much they run at but I should imagine they would be a bit pricey
    Glasgow
    Would have been much easier and probably cheaper to get an exhause fabricator to cut the old flexi out and weld a new one in its place.
    Nov 2010
    Maidstone
    Does anyone know the differences between carbide and cobalt tipped drill bits? Thanks
    Jun 2011
    Vehicle : vectra
    Year : .....
    Quote Originally Posted by signum_rob View Post
    Cobalt bits are for hard metal and carbide is for drilling predominantly ceramic material such as bathroom tile or masonry/brickwork etc.as i understand it anyway,but if it's wrong there'll be someone who'll know for sure
    Nov 2010
    Maidstone
    Thanks patch, have had a bit more of a scout on tinternet and it looks like i need colbalt bits with cutting paste at slow speed, none of which i used on the first run. You live and learn.
    Nov 2009
    Warwickshire
    I had the same problem with one of the lower bolts when I changed the flexi pipe. Burnt out three cheap drill bits - as Patch says get a cobalt bit and take your time - you'll do it Rob. Then easy to reassemble and you'll be back to a quiet car and no fumes in the cabin. Good luck with it.
    Aug 2011
    dublin
    Get some cutting compound (trefolex) to use with the drill bit, will make a huge difference, most welding or engineering suppliers will stock it.
  1. 1.8 vvt simple changes for better MPG?
    By Chip in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2012, 16:31
  2. Few simple queries about my DTi
    By OpelVectraC in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2012, 21:34
  3. A few simple questions
    Last Post: 16th January 2012, 00:05
  4. Simple little sum....
    By danBoy in forum The 'Off Topic' room
    Last Post: 8th February 2009, 18:56
  5. PC or Mac simple as that!
    By Brocks in forum General Chat
    Last Post: 11th January 2008, 21:56
