Results 1 to 10 of 11
Thread: Steering judder returned!
    East Ayrshire
    Trim : SRI XP1
    Default Steering judder returned!
    Had posted a few months ago about a steering judder/pull I had at 60mph and above. Long story short turned out to be wishbone ball joint (or so I thought) I've noticed now again that the steering judder is back at 65mph ish and increases with speed. The car also has a dull hollow knock coming from the front nearside when turning right and hitting bumps etc. The drop links are less than a year old and are the HD ones, wishbones bushes are only a couple months old (powerflex). In the last year it has had new front springs, shocks and strut top bearings I have had the car up on ramps and there is no play in anything that I can find. The wheels are definitely balanced correctly and I have also tried them front to back. I have no idea at all what it could be. Does anyone have any suggestions.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    i had this on my 1.8 the steering would judder around 65 -70 mph
    i had 2 new tyres fitted on the front and had them balanced bingo
    no judder anymore
    East Ayrshire
    Trim : SRI XP1
    I'm maybe going to need to consider that but that tyres ain't that old. They've still got 6mm on them and appear to be running straight on the balancer
    Carnoustie
    might be one of your discs has buckled
    Ronnie
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 167340
    Quote Originally Posted by stevie16v View Post
    you could try a different garage
    East Ayrshire
    Trim : SRI XP1
    It's the garage at work I use which is also used for fast road cars so their equipment is all up to date. I do most of the work myself and I'm pretty particular so always double check everything.
    Ronnie, I considered the discs as well but I'm not getting any juddering when braking so thought that would rule that out?
    Carnoustie
    yes your probably right, but looks like discs are all that's left to suspect
    East Ayrshire
    Trim : SRI XP1
    Haha, yeah you're not wrong there! I'll put the run off gauge onto them and see what it says
    Carnoustie
    also with the knocking thing might be drive shaft maybe or not related to juddering
    Dec 2010
    London
    8 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    CV joint possibly
  1. Steering judder at 70mph, possibly solved?
    By twinxster in forum Vectra C / Signum Troubleshooting
    Last Post: 27th January 2012, 22:20
  2. Odd intermittent steering judder/wobble !
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 23:34
  3. steering wheel judder when at higher speed
    By bunsen1 in forum Suspension, Wheels & Brakes
    Last Post: 29th August 2010, 15:36
  4. Hi - I've returned!
    By Terry Tibbs in forum Introduce yourself.
    Last Post: 30th January 2009, 11:02
  5. i have returned!
    By pogo in forum General Chat
    Last Post: 2nd December 2006, 10:50
