my 2.0 ecoflex is loosing coolant, cant see anywhere obvious where t is gong, any ideas?
Any dripping underneath with it running? Any white smoke from exhaust? Could be head gasket :-(
---Sent from my iPhone 5 using Forum Runner
http://www.vectra-c.com/forum/showth...ners&p=1911243
post 4
egr cooler ?
Take the header tank off and check the rear for a crack.
Most likely EGR cooler mate, common problem now, I not long had mine done
EGR cooler! Vauxhall are saying its not a problem lol, £450-£500 just for part.
Irmscher Insignia CDTI 130
can you remove the egr and cure the problem? obviously have it mapped out as well?
bump?
Its hassle, if you pop the bonnet and have someone rev the car upto 3500k revs you will see it squirting out, you could possibly use tiger seal or some sort to seal where it squirts out, as its only the outer casing that splits
try radweld for engine not radiator itl seal it up
