Thread: Another HID problem
    Regular Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Default Another HID problem
    Hi I had a problem with one of my ballasts, so I bought a replacement one from hids direct which is the slim 50w ballast, now I have one light brighter than the other, I can't get in touch with hids direct til Monday and was wondering if anyone could shed a light on what it could be? Going to try swapping the bulbs over see if it still does it, just seems strange.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    One ballast 35w and one 50w??
    May 2007
    Norwich
    Engine : 2.2 z22se
    Nope both 50w. Could it be faulty ballast?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I just find all these HID kits and separate parts just to be substandard mass produced Chinese tat to be honest mate. I've had them fitted for years, I can buy a set of bulbs and one could be brighter than the other or the ballasts are different. I think theres just too much variance in working tolerances tbh mate.
    May 2007
    Norwich
    Engine : 2.2 z22se
    Yeah I know what you mean, I bought the original kit from hids direct and the replacement ballast from them also, getting fed up with this car now time for a change. Cheers rushy
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Hmm, its not he cars fault that the HID's do not work.
    First off is that you are fitting a non oem product so you should expect issues.
    Problem is that HID's have to have a minimum 15 minute burn in time on first use, failure to do this can result in poor perfomance. This might explain the difference in light output.
    Next is the fitting, there is no need for Cancellers (HID Decoder) on the Vectra C all you need to do is enable HIDs in the UEC (do this BEFORE you fit the HIDs). If you fit cancellers and they go faulty then this will have a negative effect on the ballast and will damage them if you have not enabled HIDs in the UEC.
    So the answer to your issue is to get the correct kit for the car and enable HIDs in the UEC (£28 on ebay), job done.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    Xenons have already been activated as I done it for him.
    The problem as mentioned is cheap Chinese parts and different components, I've had the same problem before and as a result I replace ballast and bulbs in pairs, seems to avoid these issues for me at least.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Neve'o View Post
    Makes sense to do what you suggest.
    May 2007
    Norwich
    Engine : 2.2 z22se
    I've had the hids fitted for 2years and had xenons enabled last year, one of the ballasts stopped working and hids direct sent me a different ballast compared to the original set as they no longer sell them. Never had any issues before so I think it's just strange that its not a bright, could the ballast take a little while to work properly?
    regarding changing the car I've had a few problems with it since the new year where things keep going wrong and feel its time for a change, been looking at vxr's but can't find any in or around my area.
    May 2007
    Norwich
    Engine : 2.2 z22se
    The new ballast did look cheap compared to the old one.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
